Thread: Crash 11.6 20130819 comapred to 11.6 20130722
    Oct 2005
    Valdosta, GA
    248
    New version of Lightwave 11.6 20130819
    has a repeatable crash each time I use the NevronMotion.
    Each time I open the master plugin and try to open the retarget v1 is causes a fatal error and crashes lightwave
    The Kinect sensor also shows it being disconnected.
    I reloaded 11.6 prelease load the old NevronMotion plugin it works
    tried all means to make it work and same problem.
    Will report it through bug report
    May 2006
    Australia
    1
    I have just updated to the new 11.6 pre-release and same issue
    Oct 2005
    Valdosta, GA
    248
    Did a clean removal of all versions of newtek and the .newtek folder under user (windows 8.1)
    reloaded 11.6 on the computer and the Kinect device is running smooth as silk.
