Results 1 to 2 of 2
Thread: Error with skelegons
    "A skelegon with 1 vertices has been found."
    happens when i try to make skelegons in to bones 8( help!!
    found the answer in nother thread ...
    i guess you got this notification "x zero length scelegons were found. they will be converted into default bones"?
    this means that your model contains a number of one-point skelegons. this is how to delete them:
    1. in modeler, open polygon statistics window. (w key in polygon mode)
    2. select all skelegons.
    3. unselect all polygons with two or more points.
    now, only zero-length skelegons will be selected. hit del and import your model to layout again.
    cute model btw
    cheers mate.
