Thread: Output Number Format
    automator of tasks xchrisx's Avatar
    Nevada
    593
    Blog Entries
    6
    In the scene file it is called: OutputFilenameFormat
    In render globals it is just referred to as: Format (Name_0001.xxx for example)
    Is there any command in the SDK to change this? I have tried looking through the python docs as well as doing a help(lwsdk.LWSceneInfo()) and nothing comes up. I also remember this being a problem in Lscript. Anyone have any ideas besides parsing the scene file and changing it that way?
    Chris
    My Lscript Collection | LinkedIn
    3D Generalist IGT
    Oct 2003
    Near Edinburgh
    246
    Hi Chris,
    Nothing in the SDK, also had a quick search on the groups on google nothing there either. Only seems to be a manual changeable option, like a lot of other options. Note that the options changed between different versions of Lightwave, if your only using one version e.g 11.5 then that won't be a problem, but if you have a mix of versions e.g. 9.6 or 10 then the options and their indexed postions have changed.
    Regards
    Iain
    Nevada
    593
    Blog Entries
    6
    Thanks for confirming my suspicions Iain. I figured as much but it never hurts to ask Also, I believe the index change happened between 9.6 and 9.61.
    3D Generalist IGT
    Oct 2003
    Near Edinburgh
    246
    No problem
