Results 1 to 2 of 2
Thread: TED wont accept input
    Jacksonville, Florida
    31
    I have ran Config several times and as result it selected M: (150MB, four Cheetas) of my raid drives as my Video drive. That worked fine until recently. I had about 70 GB of TED prj captured rtv on it. I was 17 minutes into construction with about 25 rtvs used plus DVEs and a scroll, also with music.
    I tried then to add another rtv icon into the project from M: whereas the program crashed. Even if I click on M: with TED loaded, the program crashed. I can place items into the DDr, capture video and save to M: OK but only when I attempt to move files from M: does this problem occur. I have defraged all of my drives, tried moving all of the other rtvs from Drive M: and I have adjusted virtual memory to max for all drives but the problem persists. Hope someone has some ideas why this happens.
    Thanks for any advice.
    Ray Van Sickler
    19,283
    Though something else may be happening, the first thing that comes to mind is some sort of file appearing on that drive when you open the Toaster file window that the Toaster is choking on. At times in the past we've seen this happen, for example, with DivX files.
    You might want to consider the possibility of some type of incompatible file, or a corrupt one, or try re-generating all of the thumbnails and previews on the drive in case one of them is wonky (by deleting the hidden NewTekInfo dir on the drive.)
