Results 1 to 15 of 15
Thread: MidiDoll (Audio Mixer controller) - Now Available
    MIDIDOLL
    MidiDoll is a software developed to provide local and remote management of the audio within the TriCaster XD portable production systems developed by NewTek Inc.
    This software can be operated from a compatible MIDI controller, such as the behringer BCF2000 MIDI console. Other MIDI controllers could also be used, despite the drawbacks of requiring certain manual configuration for that purpose and lacking of specific technical support for them so far.
    MidiDoll was designed in order to help TriCaster operators, as it makes it possible to install a physical audio control table, as well as to reduce the workload of video operators entrusting the audio control to a different person who operates it either locally from a MIDI console directly connected to the TriCaster or remotely from a PC connected to the network.
    TriCaster models currently supported by MidiDoll include: TriCaster XD 40, 300, 4XX, 8XX and 8000.
    MidiDoll consists of 2 basic applications, namely MidiDoll Remote and MidiDoll for TriCaster. Both applications are independent and are designed for different scenarios. No need to install both versions. You only need to install one of the versions, depending on where you wishes to use the program.
    MidiDoll Remote. – This application shouldn't be installed on a TriCaster computer. It is designed to be installed and used on a computer separate from the TriCaster, as long as they are connected to each other across the same local network. This application enables the remote control over the Audio Mixer of your TriCaster system from a different computer or laptop.
    The application can be managed by means of a simple mouse or optionally connecting a behringer BCF2000 MIDI console from where MidiDoll Remote application can be operated.
    MidiDoll for TriCaster. – This application is designed to be installed on a TriCaster computer, and it appears in TriCaster as an add-on. It enables the control over TriCaster audio mixer from a behringer BCF2000 MIDI console directly connected to the TriCaster device.
ID:	112498 Click image for larger version.
ID:	112499 Click image for larger version.
ID:	112500 Click image for larger version.
Name:	MidiDoll Principal.jpg
    The developer recommends the use of the MidiDoll Remote application rather than the MidiDoll for TriCaster
    add-on. Although this add-on has been exhaustively tested in TriCaster systems to avoid interference with the operation
    of native TriCaster Software, NewTek strongly discourages the installation of any third party software. Therefore, it is
    highly recommended to use the MidiDoll Remote application instead.
    http://www.idcromvideo.com
    http://www.ultimatetv.es
    Feb 2012
    dinamarc
    13
    is cool. There a demo version?
    4,214
    So glad to see you have released it! Way to go
    Jef Kethley
    PIZAZZ
    www.pizazz.com
    Using:
    Panasonic UB300 4k cams
    Quote Originally Posted by Oscar89 View Post
    You can get more information, download demos or user guides, from this website:
    http://www.ultimatetv.es/Idioma/html/MidiDoll.html
    UK based Live Production
    Apr 2008
    Solihull
    671
    I want it now but the store is offline
    Quote Originally Posted by adebats View Post
    The online store is still under construction. We hope to have it operational in a few days. Meanwhile, if someone want to buy our products, please write an email to [email protected] or [email protected]
    Apr 2008
    Solihull
    671
    Thanks guys ordered - will play and report back. Looks like just what I've been waiting for Viva Espana
    May 2004
    Vancouver, WA
    1,503
    Cool!
    Replay: 3Play 820
    Cameras: Sony NX5
    Registered User digiview's Avatar
    Apr 2010
    Encounter Bay SA
    364
    Now that’s what I call innovation
    Canary in the coal-mine!
    Tricaster 860 with CS, Sony PXW-X70,PMW EX3, Gopro Black, Edius 6.5 editing System, Final Cut Pro X, Mac Pro 8 core, BMD preview Monitors.
    Apr 2008
    Solihull
    671
    I am very pleased to announce that it does do what it says on the tin. There is a minor modification require I feel to make this a killer app (having presets on the external audio controller control the same Tric input and remember positions so with one press of the button you can go from presenter mode to match coverage mode to interview in the locker room mode) but in terms of an external hard cabled piece of kit controlling the tric audio - it works. There is a bit of tweaking to do at startup but the manual runs through it all well.
    The best news is that is saved me having to buy an old Ipad... the dark side can wait a little longer.
    MidiDoll 1.2 Update is available
    This update is free for all registered users.
    If you have already registered your software, the previous license is valid for this update,
    you don't need re-register the software.
    MidiDoll V1.2 - What’s New
    MidiDoll Remote
    - Input Type Selection
    - Color Group Selection
    - Output Group (Aux and Stream) Selection
    - “Select” and “Copy To” TriCaster internal Presets (“Copy To” function only for TriCaster 8000)
    - Load/Save MidiDoll Presets
    - Several bugs corrected
    - Updated servers for online Register/Unregister
    The demo version has also been updated and can be downloaded from our website:
    UltimateTV Downloads
    Consultant
    Apr 2008
    Greater Washington, DC Area
    1,390
    Trying out the livemixer version of your midiDoll software. Have some issues. Please contact me.
    Sandy Audio Visual LLC
    NewTek Certification Testing Center
    Twitter @DCTriCaster
    TriCaster: All Models
    Cameras: Sony HDC-P1, X300
    My opinion, uncensored. The blog at www.sandyaudiovisual.com.
    Aug 2011
    Spain
    8
    Quote Originally Posted by csandy View Post
    We have answered you by email.
    Apr 2012
    Australia
    44
    Is the software product “MidiDoll” still available, as the website http://www.ultimatetv.es does not appear to have it listed.
    Consultant
    Apr 2008
    1,390
    Yes. It's called Live Remote now and is sold by 3DStorm.
