Thread: Problem using bandglue
    Spinny Spinland's Avatar
    Apr 2005
    Utica NY, USA
    2,014
    I selected two adjacent rows of quads, as show in the "before" image, with intent to merge them into a single row. LW saw them as loops because I was able to select just a few from each row and right-arrow select the rest. But, when I try to merge the two rows into a single row using bandglue, I get the results in the "after" image. Am I not using the tool in the intended way?
    Thanks in advance!
    Nov 2003
    jersey
    5,756
    Dont select loops... or parts of loops... bandglue has no idea which "direction" things should run. Instead select only 2 adjacent polys, one in each loop (after doing so, and it working... select 4 adjacent... a square, and u can see easily why bandglue gets confused byond a simple 2 selection).
    RHA Animation Tutorials
    RHR Rigging Tutorials
    RHN Nodal Tutorials
    YT Vids Tuts for all
    Apr 2005
    Utica NY, USA
    2,014
    Ah, okay, got it. That fixed me right up, thanks!
    Super Member Snosrap's Avatar
    Aug 2004
    Ohio, USA
    4,923
    Spinland, you can also select the edge loop you want to eliminate and run the "remove" command. It's the "delete" key for me, not sure if that's the default key or not though in a fresh LW .cfg install.
