Thread: License error - Win8 - 11.0.3 - build 2286
    "A license seat could not be acquired. All linense seats currently in use."
    Is anyone has similiar error while running Layout and Modeler at once ? I can start Layout, but while starting Modeler this error occur. Modeler works without Layout fine too. I did fresh install, removed old configuration files, restored default firewall settings with no luck. The only way to works normally is to use USB dongle. There is no other active computers in the network.
    - Architectural Visualizations -
    After fresh install of Windows 8 without upgrade option from Win 7 Lightwave works fine.
    Finally I found that this issue is related to Windows 8 + Kaspersky Internet Security 2013. Lightwave don't work with Kaspersky installed, even if it's firewall settings is turned off and Lightwave is setting to trusted aplication.
