Thread: Does LWPy have access to NodeEditor?
    Oct 2009
    Iceland
    55
    I looked into LWNodeEditorFuncs class and it has all methods of None type. I guess that is a bug/unimplemented. I'm right? May be is exist another way to manage nodes?
    here is a log for
    Code:
    neFunc = lwsdk.LWNodeEditorFuncs()
    for i in dir(neFunc):
        print 'member: %s'%i
        exec('print neFunc.%s'%i)
        print '------'
    Code:
    member: __swig_getmethods__
    {'rename': <built-in function LWNodeEditorFuncs_rename_get>, 'load': <built-in function LWNodeEditorFuncs_load_get>, 'setAutosize': <built-in function LWNodeEditorFuncs_setAutosize_get>, 'remInput': <built-in function LWNodeEditorFuncs_remInput_get>, 'getInputByName': <built-in function LWNodeEditorFuncs_getInputByName_get>, 'connect': <built-in function LWNodeEditorFuncs_connect_get>, 'destroyNode': <built-in function LWNodeEditorFuncs_destroyNode_get>, 'setState': <built-in function LWNodeEditorFuncs_setState_get>, 'setContext': <built-in function LWNodeEditorFuncs_setContext_get>, 'getUserData': <built-in function LWNodeEditorFuncs_getUserData_get>, 'create': <built-in function LWNodeEditorFuncs_create_get>, 'init': <built-in function LWNodeEditorFuncs_init_get>, 'cleanup': <built-in function LWNodeEditorFuncs_cleanup_get>, 'setEnvGroup': <built-in function LWNodeEditorFuncs_setEnvGroup_get>, 'save': <built-in function LWNodeEditorFuncs_save_get>, 'getRootNodeID': <built-in function LWNodeEditorFuncs_getRootNodeID_get>, 'numberOfNodes': <built-in function LWNodeEditorFuncs_numberOfNodes_get>, 'getState': <built-in function LWNodeEditorFuncs_getState_get>, 'setUpdateFunc': <built-in function LWNodeEditorFuncs_setUpdateFunc_get>, 'addNode': <built-in function LWNodeEditorFuncs_addNode_get>, 'newTime': <built-in function LWNodeEditorFuncs_newTime_get>, 'setXY': <built-in function LWNodeEditorFuncs_setXY_get>, 'destroy': <built-in function LWNodeEditorFuncs_destroy_get>, 'copy': <built-in function LWNodeEditorFuncs_copy_get>, 'usedItems': <built-in function LWNodeEditorFuncs_usedItems_get>, 'getInputByIndex': <built-in function LWNodeEditorFuncs_getInputByIndex_get>, 'OpenNodeEditor': <built-in function LWNodeEditorFuncs_OpenNodeEditor_get>, 'setUserData': <built-in function LWNodeEditorFuncs_setUserData_get>, 'isOpenNodeEditor': <built-in function LWNodeEditorFuncs_isOpenNodeEditor_get>, 'addInput': <built-in function LWNodeEditorFuncs_addInput_get>}
    member: __swig_setmethods__
    member: __weakref__
    None
    member: addInput
    None
    member: addNode
    None
    member: cleanup
    None
    member: connect
    None
    member: copy
    None
    member: create
    None
    member: destroy
    None
    member: destroyNode
    None
    member: getInputByIndex
    None
    member: getInputByName
    None
    member: getRootNodeID
    None
    member: getState
    None
    member: getUserData
    None
    member: init
    None
    member: isOpenNodeEditor
    None
    member: load
    None
    member: newTime
    None
    member: numberOfNodes
    None
    member: remInput
    None
    member: rename
    None
    member: save
    None
    member: setAutosize
    None
    member: setContext
    None
    member: setEnvGroup
    None
    member: setState
    None
    member: setUpdateFunc
    None
    member: setUserData
    None
    member: setXY
    None
    member: this
    _e062bf0b00000000_p_st_LWNodeEditorFuncs
    member: usedItems
    None
    Sep 2006
    Future Past Life
    1,894
    I don't think nodes are implemented in Python yet. Since Python resembles the C/C++ SDK I expect there will be a node class/factory for writing plug-ins. If you look there are only 13 Python plug-in classes and 33 C/C++ plug-in classes in the current release.
    Oct 2009
    Iceland
    55
    It's kind of weird, because some of classes like LWNodeInputFuncs, LWNodeDrawFuncs, LWNodalAccess.. are implemented but others are not. If it was planned, we wouldn't have partial support for nodes stuff. I think that guys were in hurry and left it as it. I hope this will be fixed in 11.5.
