Results 16 to 30 of 35
Thread: Metalink Morph Symmetry Issue
  1. #16
    Apr 2006
    Melbourne, Australia
    287
    Thanks for your experiments with this erikals, looks like a possible workaround in the event that there are no forthcoming metalink improvements. Not sure if it will be enough for eyelashes though, metalink does not like them at all.
  2. #17
    hi, forgot to answer this :]
    it's cool to see that more people would like to see these challenges solved.
    this said though, bad news, i just tested something i thought could work, but nope :/
    didn't work...
    got closer, but it's time consuming and might have a bug... (see attachment)
    http://youtu.be/x02J4tNo_4g
    it does seem to work excellent in the example you posted though...
    http://www.youtube.com/watch?v=PNiuRnisK98
    Attached Files Attached Files
  3. #18
    btw, have you tried hardlink instead of metalink? might work...
  4. #19
    Apr 2006
    287
    Hardlink has more trouble handling these deforming surfaces than metalink, unsurprisingly. My example works (from a distance at least), because I had to resort to weighting and morphing each eyelash to match the eyelids, which of course is not very practical (nor accurate).
  5. #20
    Dpont's Meta Pointer seems to work. You have to bake the cage objects though...
  6. #21
    what problems did hardlink give though, same thing?... inaccuracy?...
    hardlink example >
    http://forums.newtek.com/showthread....=1#post1295071
  7. #22
    May 2006
    France
    3,961
    Quote Originally Posted by VermilionCat View Post
    ...Meta Pointer seems to work. You have to bake the cage objects though...
    Don't need to bake with Meta Fit node.
    Denis.
  8. #23
    That could be interesting! \:]
    hmm, so it could be used as a lattice deformer as well?...
  9. #24
    Quote Originally Posted by dpont View Post
    Hi, Denis!
    Meta Fit works similar to Metalink in my test. MetaPointer works completely symmetrical.
  10. #25
    might be a misunderstanding, as the word should have been "calculate" and not "bake" ?
  11. #26
    Yeah, sorry. You have to generate .mdd for the cage object.
  12. #27
    May 2006
    France
    3,961
    Hi, Denis!
    Meta link works symmetrical too, no mdd,
    Denis.
  13. #28
    Then am I doing something wrong?? Now they seem all different...
ID:	110726   Click image for larger version.
ID:	110725   Click image for larger version.
ID:	110724   Click image for larger version.
  14. #29
    May 2006
    France
    3,961
    Don't know,
    Meta Pointer and Meta Fit node use the same internal process,
    so I can't explain such different result.
    Denis.
  15. #30
    Apr 2006
    287
    A lot more drift, with the hairs moving away from each other in clumps.
    Can't seem to get it to do anything... how do you use it?
