Results 1 to 15 of 16
Thread: Improvements needed!!!!!!
    Sep 2012
    San Bernardino, CA
    4
    Can you add more view and mic inputs as well as add sle mic to all trickster models. Also increase the internal hard drive storage space so that I do not have to Cary external storage units. Also can you add some sort of wireless camera option as well so that there is an accessory we can get from new reckless that attaches to camera to make it where we can have better coverage for our events
    19,329
    What, no cappuccino maker?
    (And - what is an "sle mic"?)
    Edit: Oops, I forgot, sorry ... "!!!!!!!!!!!!!!!!!!!!!!!!!!!!"
    Sep 2012
    San Bernardino, CA
    4
    Improvement sugestions
    I meant xlr mic inputs an you make that available on all tricaster units. Also can you add a wireless mic option as well as a wireless camera option as well so that some of my camera operators do not have to be tied to a cable that has a limited range. Also can you use larger hard drives and add more hard drive bays for all tricaster units as well. Also can you make it where I can have 4 video outputs where I can have 2 for the controls and 2 for the live video broadcast for what my Internet users would see.
    19,329
    .... ummmm .... sure. (Do you have a drill? How are you at soldering?)
    Quote Originally Posted by mikeytward View Post
    Most TriCaster models have XLR connectors already, though some do not. XLR connectors are not for everyone, and some models have so many inputs and outputs that there simply isn't room on the chassis for XLRs (much less Neutrix connectors, which are preferable).
    Here you go: Wireless mic link
    ... as well as a wireless camera option as well so that some of my camera operators do not have to be tied to a cable that has a limited range.
    I think this is what you're looking for. (You just need one per camera.)
    Et voila ....
    All HD TriCasters already allow you to use one monitor for controls, one for previews, and support multiple live video and audio outputs. (Some models do much more than this.)
    Jan 2010
    Maryland
    76
    I think all of these improvements will be in revision 11323.5C
    Sep 2012
    San Bernardino, CA
    4
    I never done soldering but if you can have this added to the next model that you releAse it would be very helpful. Also please add more video input ports for the cameras as well. Since I was thinking something around 8 would be a good starting point for those whoso not do very large brodcasts.
    19,329
    Here you go, Mikey: TriCaster 8000 supports everything you've asked for and much more that you haven't mentioned yet.
    Sep 2012
    San Bernardino, CA
    4
    Well I would need closer to 12 video and audio inputs. Can you have this done in the next release.
    19,329
    You can connect as many as 144 cameras to a single input on TriCaster 8000 using a router. It has eight of these inputs. Please get back to me once you own more than 1152 cameras. Thanks.
    UK based Live Production
    Apr 2008
    Solihull
    671
    This thread has got to be one of the funniest I've seen for a while beating the debate about the newtek sheep transition...
    19,329
    You must respect the sheep!
    Aug 2011
    Richmond, VA
    951
    How do I select the stream on the input?
    E. Lee Dickinson | President
    www.avprva.com
    19,329
    That's what the decoder is for (you aren't going to ask me to do all the homework, are you?).
    Aug 2011
    Richmond, VA
    951
    Okay, so I drilled the SDI connector out and soldered the power lead from the encoder in, just like you said, but it's not working.
    (Seriously though, being able to natively decode an IP stream from a terradeck or anything else would be sweeeeet.)
    www.avprva.com
    19,329
    Good point; I expect we'd be happy to hook those guys up with the appropriate API if they wanted to have the ability to send directly to TriCaster. Got any buddies there?
