Thread: Blurring backgrounds on virtual set zooms...
    From Browser To Broadcast jmmultex's Avatar
    Jan 2004
    Trenton, NJ
    452
    It would be interesting to allow two background layers in Virtual Sets: a standard BACKGROUND and a BLURRED BACKGROUND, and to allow a % mix level between the two to be assigned based on the percentage of zoom on the set. (Effectively making the unblurred background more transparent to let the blurred background show through more at higher zoom levels.).
    This could create an interesting Depth Of Field look that could soften background elements on closeups and help sell certain types of sets...
    Just a thought...
    -John
    John Mahoney
    GNURAL NET, Inc.
    Trenton, NJ 08691
    [email protected]
    http://www.gnuralnet.com
    Gear:
    Gnural Net LiveToAir, TC1, TC1LP, MDS1, TC8000, Cameras: NDIHX-PTZ1, PTZ Optics ZCAM 20x
    19,162
    You could 'kinda sorta do' that now, John, by dong a cross-fade between blurred and unblurred versions of the same set while zooming. The co-ordination would pretty much mandate a control surface, mind you.
    Jan 2004
    Trenton, NJ
    452
    I've tried doing it that way, and just found it challenging to execute on it consistently (plus I don't have a control surface of my own and need to borrow one when required... ). I usually end up doing cuts-only between "pre-baked" blurred and unblurred set versions, and that works well in a keyboard-only setup.
    I just thought it would be useful to have it baked in at some point.
    Thanks!
    -john
    John Mahoney
    GNURAL NET, Inc.
    Trenton, NJ 08691
    [email protected]
    Gear:
Similar Threads
  1. Trouble with zooms and pans
    By Billybopper1 in forum Aura - General Support
    Last Post: 02-21-2009, 11:45 AM
  2. Zooms on stills have lots of shimmer
    By ScorpioProd in forum VT - General Support
    Last Post: 08-15-2004, 08:48 PM
