Results 1 to 12 of 12
Thread: Hidden Break up tool? Csg slice
    14,676
    Dont recall seeing this tool before, it actually create quite precise cut outs if you want to fracture simple pieces to destroy, not sure if it is available in the fracture tab somewhere too?
    You need to create two layers with geometry and works like some sort of boolean cut out with pieces created at once so you can select connect and move them or use in bullet.
    Found it accidently by browsing through utilities/plugins, and it is called Csg slice.
    Michael
Name:	Csg slice.jpg
    Nov 2006
    Burbank, California USA
    4,576
    Nice find.
    Profile piece
    2010 Reel
    'The X's' Reel
    14,676
    Quote Originally Posted by nickdigital View Post
    Nice find.
    You can also run the explode parts command in case you want to explode to morph, but the parts is disconnected from each other by just running Csg slice.
    a tip ..let´s create a box, run the python command bubbles with equal min/max radius...that will create spheres on the point edges of box, you can then scale normals by using point normal move which
    will let you define the spheres closer or offset from the box to get a cookie cutter object, you can also fractalize the spheres a little to get it uneven, then copy the spheres to background layer and then run
    Csg slice.
    Since I can´t see this command in fracture tab or within those tools, they should be branched and placed beneath fracture in a manual fracture menu.
    Michael
    San Antonio, Texas, USA
    13,054
    These are part of the Fracture tool.
    UI / UX Designer @ NewTek
    14,676
    Quote Originally Posted by Matt View Post
    Im sorry ..but I do not see that tool inside of the fracture tool, the only similar one is to use the fracture and use algorithm/halves, but that doesn´t give the exact cut out, as using it from the utilities and Csg slice.
    You just mean that they are part of the whole fracture toolset, but not inside the fracture command?
    Michael
    7,884
    Fracture tool is executing them to fulfill its work - it's basically doing what I am doing in mine video, but butter Boolean implementation..
    https://www.youtube.com/watch?v=ud52wxYMygc
    Do what I am showing in video, then press csgSlice instead of Boolean and you have two pieces independent!
    14,676
    No..that is a different cutting procedure and not what Ive´shown, unfortunatly I do not have camtasia studio installed on my laptop so I cant show you, the fracture tool doesnt yield the same exact cut out
    from geometry in a background layer as I pointed to in my image attachement, so why confusing them to be working the same inside of the fracture tool? I understand if the fracture tool calls upon that command to fullfill its destruction, but In such case
    it must be clear that it doesn´t yield the same results as if you were to run it the way I did.
    I havent checked using a division grid, distorting it and running Csg slice, will test that tomorrow, bedtime now.
    Dec 2008
    Ghana West Africa
    841
    Nice discovery Prometheus but why is this not documented?
    Is it not worth documenting?
    skeptic lertola2's Avatar
    Dec 2008
    New York City
    1,110
    Very interesting. There are other Csg tools as well. What do you think the CsgCleanup does?
    Sep 2003
    France
    498
    Thank you for the info
    CSG Slice is very interesting.
    As another tool hidden from Fracture ago "Explode Parts" He has no button. You must go to "Edit Menu Layout" / "Search" / "Explode" and add it to a tab.
    14,676
    Quote Originally Posted by Hail View Post
    Beats me...they must have missed it, it is worth documenting better, and it should really have it´s own menu branch and buttons beneath the fracture tool really.
    Cow Orker cagey5's Avatar
    Manchester UK
    3,273
    Thanks for that. That is sooo useful for doing accurate fractures.
    Forum Tips
    If English is your first language, you should know it's 'losing' and not 'loosing'!
Similar Threads
  1. slice through skin
    By burvis in forum LW - General Techniques, Tips & Tricks
    Last Post: 04-12-2011, 11:42 AM
  2. Drill>Slice : am i using it properly?
    By stevmjon in forum LightWave v9.6 Discussions
    Last Post: 09-29-2008, 09:08 PM
  3. What causes this slice?
    By Johnny in forum General Support
    Last Post: 02-04-2004, 09:27 PM
  4. How to slice a engine in two
    By ned in forum LW - General Techniques, Tips & Tricks
    Last Post: 09-18-2003, 08:13 AM
