Thread: Textures
    Mar 2008
    Prince Edward Island
    492
    Textures
    Hi all. I purchased a coin from Turbosquid. I open the object and it looks good (see attached). I paste it into another object and the textures are gone (see attached). Any ideas?
Name:	Screen Shot 2012-08-14 at 2.24.55 PM.png
ID:	106240   Click image for larger version.
Name:	Screen Shot 2012-08-14 at 2.25.02 PM.png
    automator of tasks xchrisx's Avatar
    Nevada
    593
    Blog Entries
    6
    My guess is that it is using a surface that already exists in the second object. For example if the coin in the original object is using Default surface, and you copy and paste it into another object that has a Default surface, it will not replace the surface. So my suggestion would be to rename the surface before copying it over to the other object.
    My Lscript Collection | LinkedIn
    3D Generalist IGT
    Most likely it's a UV texture and your UV map doesn't exist on the new object.
    Chris Zapara
    VFX Supervisor, MFX
    www.mfxdesign.com
