Results 1 to 9 of 9
Thread: How to make a passenger train trail a locomotive?
    Jan 2012
    Erie
    42
    This is driving me nuts. I figured I would export the motion path used by the locomotive and shift the frames about 10 frames for the passenger car... however, it doesn't work reliably. In certain areas, it stays the appropriate distance back, but in others, it rides to close or too far back. Tried adjusting the keyframes manually, but that didn't work out terribly well either.
    Is there a better approach for doing this? Parenting doesn't seem to work either.
    Nov 2006
    Burbank, California USA
    4,576
    Profile piece
    2010 Reel
    'The X's' Reel
    Registered User THREEL's Avatar
    May 2006
    Bryan
    1,226
    Quote Originally Posted by nickdigital View Post
    Nick,
    You probably listed this, but since I can't seem to open it as a Quicktime file, I thought I'd share it as a YouTube file.
    http://www.youtube.com/watch?v=zg0xa2Ovvxw
    Hope this helps and a BIG thanks to William Vaughan for all the help he's shared over the years.
    THREEL, but you can call me AL.
    John 3:16
    Psalm 14:1
    Philippians 2:9-11
    Hastings, New Zealand
    7,731
    Dr Follower in Relativity has a "wizard" to help setup stuff like this.
    Scene Destroyer DrStrik9's Avatar
    May 2007
    Portland, Oregon
    1,684
    Quote Originally Posted by SplineGod View Post
    It seems Relativity is getting to be one of the most overlooked things in LW. It ROCKS.
    7,731
    I agree. Its been around long before LW had native expressions and is very powerful.
    Definately worth digging into.
    Jan 2012
    Erie
    42
    Follower - Pitch doesn't work?
    Thanks for the tips with Follower, it works well. The only issue I am running into is with align to path. Heading aligns properly, but not Pitch? Rather than angling up on my track for a hill, the cars tend to tilt down?
    Axes grinder- Dongle #99
    Seattle
    14,726
    Quote Originally Posted by mwilcko View Post
    Are they actually tilting down, or are they just not tilting at all?
    I'm speculating that "Align" might not work with Follower, since it's not really a motion path. Or you might need to apply Follower or something like Follower to the cars' rotation channels.
    EDIT: FWIW, Follower here is faithfully duplicating all target rotations, w/o even using its own "Align to Path" checkbox.
    Praise to Buddha! #resist
    Seattle
    14,726
    inherently slow mouse operations
    Quote Originally Posted by THREEL View Post
    While I think that Proton's technique demonstrated above was an excellent illumination of how LW's tools can work synergistically/additively to achieve effects that otherwise would be difficult, as a practical technique I don't think most people would want to create a roller-coaster track in this manner, ie via bone deformation.
    FOLLOWER UI: I don't think it's very workflow friendly that neither ENTER on the numpad nor ENTER on the main keyboard dismisses the Follower panel: while using Escape cancels any changes the user may have made to numeric fields in the panel.
    Basically, the user is forced to use the CONTINUE button to exit the panel with changes intact, which as a mouse operation is inherently slow.
    (While, for completeness, I also think there should be an explicit Cancel button, that users can see, not just the implicit Escape option, which noobs won't know about. If the button were labeled "CANCEL (Esc)" it would also be consistent with LW user interface conventions.)
