Results 1 to 9 of 9
Thread: PSD Export Depth Layer - It's White
    Feb 2010
    Kansas City
    1,140
    Why is the depth layer white, when I do a PSD export? What good is this or what am I doing wrong?
    "Once one can articulate an important idea into a concise statement, then one can use the statement and not have to have the fear of changing behavior." - Ed Catmull on Pixar creativity
    Check that your z-depth isn't set to a greater depth than your scene, in render globals. Try exporting the depth pass with the Render buffer Export instead, and set it to .exr instead of .psd
    Confirmed -
    Aug 2006
    S
    3,511
    Which version of LW and PS are you using? Sounds like a bug.
    Feb 2010
    Kansas City
    1,140
    Thanks Toby. I'll try that.
    @meshpig - LW11 and PS 5. I figured maybe the 32 max was too much on the depth setting (the default), but don't know what to use as a measure.
    Thanks to you both. I appreciate your time.
    Pessac
    5,033
    Look at your scene from overhead and note the distance from the camera to the furthest object.
    B
    LightWave 3D Trial Edition
    Feb 2010
    Kansas City
    1,140
    Thanks BeeVee. Does this 32 mean the number of gridlines?
    B
    Pessac
    5,033
    Depends on the grid size! Each one of the lines is whatever your grid is set to.
    B
    Near Beaverton, OR
    1,219
    I ran into this sometime back and even though I searched here, I never came across an answer until I just happened to try a different camera in LW.
    Assuming you do have the depth settings correct, you'll need to switch to Classic Camera in order for the render buffer to actually get exported. Why, I've no idea.
    Dec 2006
    Philadelphia, PA
    5,738
    Also make sure the camera is not looking through a transparent object like a window that is close to the camera. The depth pass will not 'see' through the window.
