Thread: Varying Width of Bricks
    What do I know? JBT27's Avatar
    Jan 2004
    Chester, England
    2,250
    I'm using IFW2_Bricks for a wall of a Roman amphitheatre - it's an image for a 1.8m x 5m hoarding, so procedural (and time) seemed the best way to tackle this, rather than image maps and paint jobs.
    IFW2 is sophisticated and ideal ... except I cannot vary the width of the bricks, nor think of a way to do that ... does anyone have any ideas please?
    It's obviously great for modern walls with mass produced same sized bricks, but not so good for ancient walls which are not so perfect.
    I've emailed RJJ, but it's also quite urgent, so if I'm missing anything, I'd appreciate some ideas.
    Thanks.
    Julian.
    LW 2015.3 Win 10 Pro 64bit
    http://www.take27.co.uk
    Here is a simple starting position. Alpha max controls max grout distance between regions and some turbulence to distort edges.
    You can add more variations to regions using IFW2 color region tools or some waveforms to bevel input.
    You can make each brick with individual image texture too - just connect 2D image output to color inputs of IFW2_RegionColorSW node.
ID:	104549   Click image for larger version.
    - Architectural Visualizations -
    Jan 2004
    Chester, England
    2,250
    Many thanks. RJJ also responded to email with some ideas, which were along these lines.
    But even here the physical width of the brick is still fairly even. A procedural that mimicked ancient stone walls, with greatly varying widths and even heights, would be really handy. Maybe there is one ... but IFW is so good it struck me that it's the one variable it's missing.
    Thanks again.
    Julian.
    No problem. Maybe the best thing in this situation is to make 2D alpha image by hand in PS to simulating uneven spacing with some distortions ? Some time ago I had situation with non-standard bricks, stones and painting the mask was an only way to do it.
    Jan 2004
    Chester, England
    2,250
    Agreed. We tend to need to do more ancient walls than not, so this is often the case - luckily we have alot of Medieval and even Roman walls around here, and for the last job, I photographed some and made large plates of uneven stonework, using the shapes and the colours derived from those walls.
    It's a far better way, just more time consuming and laborious.
    The client loved it, so I guess that makes it OK then
    Julian.
    Aug 2010
    Kernow
    2,031
    Have you thought of using the standard Planks_2D texture?
    Jan 2004
    Chester, England
    2,250
    I'll try that - good call - thank you!
    Julian.
