Results 1 to 11 of 11
Thread: Change a model during animation..is this possible?
    Question Change a model during animation..is this possible?
    Hey LW'ers,
    I need to break one of the rules I have never broken before. My character's animation is half done but I need to change and add to the model. Is there a way to do this without loosing the time spent on the animation?
    Is it possible to add geometry to the original model, weight map it, save it as a new object, setup the proper bones and hierarchy, and then replace the object without issue? (Ideally keeping the animation but having the new geometry and rig work)
    I have tried a couple times but get "Error: object loading failed".
    Is this possible or is this destined to tangle things up?
    Thanks in advance!
    "Remember, wherever you go, there you are!"
    Check out my website and demo reel.
    Nov 2006
    Burbank, California USA
    4,576
    You should be able to do what you want. What if you just load the object into a clean Layout. Make sure your new object is fine.
    Profile piece
    2010 Reel
    'The X's' Reel
    Axes grinder- Dongle #99
    Seattle
    14,726
    I've never tried it, but "saving the rig" gets tossed around, so maybe you can at least salvage the skeleton.
    Praise to Buddha! #resist
    Ok, the object now loads without the error message..forgot about the skelegons in the objects layer. So it should be just a matter of setting up the bones.
    Thank you for the help so far.
    Nov 2006
    4,576
    Another option would be to go back to a scene where it's just the rig (hopefully you have one), swap out your object, add whatever bones and rig controls that you need.
    Go to your file that has the animation and save out the motions of your animation.
    Then load those motions onto the new rig. MotionCycleGN (v.2.0) is a handy lscript to do this.
    http://thespread.faulknermano.com/_t...read/index.htm
    Adjusting a rig once you've animated is possible, it's just a headache.
    Profile piece
    2010 Reel
    'The X's' Reel
    Seattle
    14,726
    What kind of changes would destroy the utility of the original model?
    Nov 2006
    4,576
    I'm referring more to adjusting/adding to the skeleton. The model should be fine.
    Profile piece
    2010 Reel
    'The X's' Reel
    Seattle
    14,726
    I meant the OP.
    Nov 2006
    4,576
    i meant the op.
    op?
    Profile piece
    2010 Reel
    'The X's' Reel
    Seattle
    14,726
    OP= original poster.
    s/he seemed to think that the planned alterations would make the model unusable for that animation.
    Nov 2003
    jersey
    5,763
    nothing to it... just make whatever alterations to your object, weight accordingly and it'll still work fine. The only time you get problems like this is if you go changing proportions, limb lengths, etc, then ur screwed.
    RHA Animation Tutorials
    RHR Rigging Tutorials
    RHN Nodal Tutorials
    YT Vids Tuts for all
