Thread: Hub crashing LW 11 64 bit rev 2238
    14,590
    I suddenly got the hub screwed up, it crashes all the time when I try to start modeler or layout, this seem to have been occouring after I installed ozone6, but not quite sure if that is causing it.
    Lw 11 64 bit build 2238.
    I can close the error message and work with either modeler or layout, but can not get the hub to function.
    Happy eastern..cheers.
    Michael
    TD/Animator lino.grandi's Avatar
    Jun 2003
    Rome
    1,700
    Do you have LW32 installed? If so, Try to launch 32 version, close it and star the 64 version.
    If this doesn't work, you may have to delete your config files (the hub related one could be enough).
    Hope this helps.
    Lino Grandi
    3D Development, LightWave 3D Group/NewTek, Inc.
    https://www.lightwave3d.com/
    LightWave 3D Group YouTube channel:
    http://www.youtube.com/user/Official...?feature=watch
    My YouTube Channel:
    http://www.youtube.com/user/linograndi?feature=mhee
    14,590
    Quote Originally Posted by lino.grandi View Post
    Hope this helps.
    Thanks Lino, well no I donīt have 32 installed of Lw 11, only 9.6 and 10.1 versions of 32 bit installed.
    I will delete the configs,Ill try with the hub only first.
    I suspect the ozone6 install thou, since after that it started to screw up.
    Cheers.
    Michael
    14,590
    Clearing all the configs didnīt help, neither did uninstalling the ozone plugin help.
    Looks Like something is screwed up and I have to Uninstall Lightwave and install fresh.
    Michael
