Thread: Interactive Slider
    Super Member Kevbarnes's Avatar
    Nov 2006
    Gloucestershire UK
    495
    Interactive Slider
    Hi I trying to script an interactive slider.
    see Attached rar file with scripts 'version01' and 'version02'
    I've got so far with 'v01' which establishes the slider
    but I don't know how to implement what I think is a 'Call-Back'?.
    I've tride using 'reqopen' and adding what I think is a refresh action on the slider
    but nothing seems to work - is this possible?
    Attached Files Attached Files
    "one rig to rule them all"
    PC Spec: Intel i7 X980 3.33GHz | 24Gb | ATI FirePro V5800 | W7
    https://vimeo.com/kevbarnes/showreel
    https://littlstar.com/kevbarnes
    https://www.talenthouse.com/kevbarnes
    Code Muppet evenflcw's Avatar
    Stockholm, Sweden
    2,642
    You should use the callback to set your internal data variable. Also don't forget to set the initial value of the control to the same as the internal one so they don't start out of synch.
    Code:
    options
        if(reqisopen()) reqend(); //closes previous panel if any open
        reqbegin("SliderControl");
        c0 = ctlchoice("Control Axis",ControlPos,@"X","Y","Z"@);
        c2 = ctlslider("Slider",1,1,100);
        setvalue(c2, SlideAmount); //starting value when panel opens
        ctlrefresh(c2,"refresh1");
        reqopen();
    refresh1: value
        SlideAmount = value; //or = getvalue(c2);
    Nov 2006
    Gloucestershire UK
    495
    thanks evenflcw
    that now works great.
    I'll have to do the same action on the 'Axis choice' variable as its only getting the initial value.
    Many thanks
    Kev
