Results 1 to 12 of 12
Thread: Create a square
    Create a square
    This is my first attempt at trying to understand the new Python scripting. It's a modeler script that creates a square polygon and assigns values for uv, weight and vertex color maps. I tried to find a way to set the actual surface color, but couldn't see how to do it.
    Code:
    #! /usr/bin/env python
    # -*- Mode: Python -*-
    # -*- coding: ascii -*-
    This is a LightWave Command Sequence plug-in (Modeler) that creates
    a square.
    import sys
    import lwsdk
    __author__     = "Clinton Reese"
    __date__       = "Feb 29 2012"
    __copyright__  = "Copyright (C) 2011 Clinton's 3D Creations"
    __version__    = "1.0"
    __maintainer__ = "Clinton Reese"
    __email__      = "[email protected]"
    __status__     = "Example modified"
    __lwver__      = "11"
    class make_square(lwsdk.ICommandSequence):
        def __init__(self, context):
            super(make_square, self).__init__()
        # LWCommandSequence -----------------------------------
        def process(self, mod_command):
            edit_op_result = lwsdk.EDERR_NONE
            mesh_edit_op = mod_command.editBegin(0, 0, lwsdk.OPSEL_USER)
            if not mesh_edit_op:
                print >>sys.stderr, 'Failed to engage mesh edit operations!'
                return lwsdk.AFUNC_OK
            ptID = []
            pt = [ -1.0, 0.0, -1.0 ]
            uv = [ 0.0, 0.0 ]
            rgb = [1.0, 0.0, 0.0]
            ptID.append(mesh_edit_op.addPoint(mesh_edit_op.state, pt))
            # different from c, dimension of vmap is not used?
            #mesh_edit_op.pntVMap(mesh_edit_op.state, ptID[0], lwsdk.LWVMAP_TXUV,"MyUVMap", 2, uv)
            mesh_edit_op.pntVMap(mesh_edit_op.state, ptID[0], lwsdk.LWVMAP_TXUV, "MyUVMap", uv)
            mesh_edit_op.pntVMap(mesh_edit_op.state, ptID[0], lwsdk.LWVMAP_WGHT, "MyWeightMap", 0.0)
            mesh_edit_op.pntVMap(mesh_edit_op.state, ptID[0], lwsdk.LWVMAP_RGB, "MyVertexColorMap", rgb)
            pt = [ -1.0, 0.0, 1.0 ]
            uv = [ 0.0, 1.0 ]
            rgb = [0.0, 1.0, 0.0]
            mesh_edit_op.pntVMap(mesh_edit_op.state, ptID[1], lwsdk.LWVMAP_TXUV, "MyUVMap", uv)
            mesh_edit_op.pntVMap(mesh_edit_op.state, ptID[1], lwsdk.LWVMAP_WGHT, "MyWeightMap", 0.25)
            mesh_edit_op.pntVMap(mesh_edit_op.state, ptID[1], lwsdk.LWVMAP_RGB, "MyVertexColorMap", rgb)
            pt = [ 1.0, 0.0, 1.0 ]
            uv = [ 1.0, 1.0 ]
            rgb = [0.0, 0.0, 1.0]
            mesh_edit_op.pntVMap(mesh_edit_op.state, ptID[2], lwsdk.LWVMAP_TXUV, "MyUVMap", uv)
            mesh_edit_op.pntVMap(mesh_edit_op.state, ptID[2], lwsdk.LWVMAP_WGHT, "MyWeightMap", 0.75)
            mesh_edit_op.pntVMap(mesh_edit_op.state, ptID[2], lwsdk.LWVMAP_RGB, "MyVertexColorMap", rgb)
            pt = [ 1.0, 0.0, -1.0 ]
            uv = [ 1.0, 0.0 ]
            rgb = [1.0, 1.0, 1.0]
            mesh_edit_op.pntVMap(mesh_edit_op.state, ptID[3], lwsdk.LWVMAP_TXUV, "MyUVMap", uv)
            mesh_edit_op.pntVMap(mesh_edit_op.state, ptID[3], lwsdk.LWVMAP_WGHT, "MyWeightMap", 1.0)
            mesh_edit_op.pntVMap(mesh_edit_op.state, ptID[3], lwsdk.LWVMAP_RGB, "MyVertexColorMap", rgb)
            polygon = mesh_edit_op.addPoly(mesh_edit_op.state, lwsdk.LWPOLTYPE_FACE, None, "MySurface", ptID)
            #mesh_edit_op.pntVPMap would be used at this point to create discontinuous uv values for the polygons
            mesh_edit_op.done(mesh_edit_op.state, edit_op_result, 0)
    ServerTagInfo = [
                        ( "Python Basic Square", lwsdk.SRVTAG_USERNAME | lwsdk.LANGID_USENGLISH ),
                        ( "Make Square", lwsdk.SRVTAG_BUTTONNAME | lwsdk.LANGID_USENGLISH ),
                        ( "Utilities/Python", lwsdk.SRVTAG_MENU | lwsdk.LANGID_USENGLISH )
    ServerRecord = { lwsdk.CommandSequenceFactory("LW_PyMakeSquare", make_square) : ServerTagInfo }
    Geist im Maschine Gorbag's Avatar
    Lakewood, CO
    39
    Ideally, you'd just be able to append code like this to your script to set a color for the surface:
    Code:
            # apply a color to 'MySurface'
            surface_funcs = lwsdk.LWSurfaceFuncs()
            surface = surface_funcs.first()
            while surface:
                if surface_funcs.name(surface) == "MySurface":
                    surface_funcs.setFlt(surface, lwsdk.SURF_COLR, [0.0, 1.0, 1.0])
                    break
                surface = surface_funcs.next()
    or
    Code:
            new_color = lwsdk.Color(0.0, 1.0, 1.0)
            while surface:
                    surface_funcs.setFlt(surface, lwsdk.SURF_COLR, new_color)
                    break
    However, I've discovered an implementation bug with respect to the setFlt() method with prevents it from functioning properly. I'll have to get this fixed.
    Aug 2006
    Hendersonville, NC
    6,959
    Quote Originally Posted by Gorbag View Post
    Such a witty avatar and so few posts!
    shrox www.shrox.com
    Heavy Metal Landing
    Lakewood, CO
    39
    Quote Originally Posted by shrox View Post
    Um, what in particular is "witty" about my face? A lot of people use their faces as their avatars. You yourself are using your face. Sure, I'm a lot older than I used to be, but I don't think that's reason to make fun of somebody--I've tried to take care of myself.
    I mean, here's a recent photo:
    Yeah, I've got a lot less stair than I used to have, but I really don't think it's appropriate to make fun of somebody's face, that's all I'm saying.
    Is it because the function takes a double and python only does floats?
    Lakewood, CO
    39
    Quote Originally Posted by clintonman View Post
    No, it's because the function takes a double pointer (from lwsurf.h in the LWSDK):
    Code:
      int  (*setFlt)(LWSurfaceID,const char *, double *);
    And internally, that is not being processed by the wrapper layer in a form that Python can digest. Python doesn't really know what a "double *" is or how to handle it directly, so unless I deal with it explicitly (by some type of conversion), it gets passed around as an opaque type. As an opaque type, you cannot modify the data to which the pointer points.
    Hope that made sense.
    Makes sense to me. Thanks.
    Jun 2012
    Belgium
    4
    were you able to find a solution to the setFlt problem? I am running into the same issue right now.
    I don't really know how to solve it.
    I was looking at ctypes since it seems ctypes allows you to work with pointers in Python but ctypes is not part of the LW Python distribution.
    Any help much appreciated
    Code:
    a square.
    import sys
    import lwsdk
    __version__    = "1.0"
    __lwver__      = "11"
            ptID = []
            uv = [ 0.0, 0.0 ]
            uv = [ 0.0, 1.0 ]
            uv = [ 1.0, 1.0 ]
            uv = [ 1.0, 0.0 ]
            #new_color = lwsdk.Color(0.0, 1.0, 1.0)
            new_color = [0.0, 1.0, 1.0]
            while surface:
                    break
            thecommand = mod_command.lookup(mod_command.data, "SETLAYER")
            i="1"
            cs_options = lwsdk.marshall_dynavalues(i)
            result = mod_command.execute(mod_command.data, thecommand, cs_options, lwsdk.OPSEL_USER)
            i="2"
            i="3"
            i="9"
    ServerTagInfo = [
    This code works for me. Be sure you are running Lightwave ver 11.0.1, it doesn't work in LW 11.0
    Updated script for 11.5 which uses "surface_funcs.set_float" instead of "surface_funcs.setFlt(surface, lwsdk.SURF_COLR, new_color)". Also commented out the extra set layer commands.
    Code:
    a square.
    import sys
    import lwsdk
    __date__       = "March 8 2013"
    __version__    = "1.0"
    __lwver__      = "11.5"
            ptID = []
            uv = [ 0.0, 0.0 ]
            uv = [ 0.0, 1.0 ]
            uv = [ 1.0, 1.0 ]
            uv = [ 1.0, 0.0 ]
            while surface:
                    #try float for lw11.5 - worked
                    #surface_funcs.setFlt(surface, lwsdk.SURF_COLR, new_color)
                    surface_funcs.set_float(surface, lwsdk.SURF_COLR, new_color)
                    break
            i="1"
            #remove to avoid confusion
            #i="2"
            #cs_options = lwsdk.marshall_dynavalues(i)
            #result = mod_command.execute(mod_command.data, thecommand, cs_options, lwsdk.OPSEL_USER)
            #i="3"
            #i="9"
    ServerTagInfo = [
    Lakewood, CO
    39
    Yeah, I'm sure there will be lots of these little items that will need to be addressed. Integrating Python was not a simple undertaking, and it'll be on-going for a while yet.
    Sorry for the inconvenience.
    Explorer souzou's Avatar
    Sep 2003
    London, UK
    420
    lol. I think he was just taken aback by your lack of banisters.
    Matt Knott / VERSUS
    http://www.versus.nu
