Thread: Making Polygons Co-Planar
    Is there a command in LW that one can use to make selected polygons co-planar? This would be useful in the creation of SDS objects.
    Jeffrey R. Markham
    [email protected]
    Banned Epita's Avatar
    Not where you are
    379
    i think i know what you want, try to merge the polys together with unifie, or merg polys. either work or go bang!
    Epita
    do you mean put different surfaces on each side of the poly? if so you need a plugin in Eki'e modpak it will make a zero thickness extusion that fakes this perfectly... it's called Q-air.
    go here for plugin demo
