Results 1 to 2 of 2
Thread: HotKeys and Numbered Effects
    Two things.......
    Is there anyway to disabe F1 bringing up the help screen and make it so it only brings source 1 onto the main bus. We've been using the toaster for more live switching lately and it can sometimes be a pain hitting F1 and not bringing up my number 1 source. It's too easy not to remeber to click back on the switcher module after I click in a DDR.
    Also, the number box for the DVE effects......Is it possible to make the selection like it was in the Amiga days when you could just type in a number on the number pad and it would auto-type and load effects, cg's, etc.
    Or maybe at least make it so I can click on the box and then type in the number. Right now you have to type in that box, erase the old numbers, then type in the new ones.
    Everything happens very quickly in our productions, and I'm trying to streamline stuff some. I've heard of Toaster-Script, but I don't know much about it and what it can do, or if this stuff is even in its league.
    If you aren't confused, you aren't working hard enough........
    You can put Caps-Lock on and all commands will go to the Switcher.
    Faraz Ahmed - Amitrace
    www.Amitrace.com
