Results 1 to 15 of 27
Thread: Sub Station
    Sub Station
    A render of a concept i've been working on. All work done in Lightwave 10 and Photoshop.
    Carbon fibre dongleŽ 50one's Avatar
    Jan 2011
    Honeycomb hideout
    2,384
    http://www.sinelab.com/illustrations...bstation12.jpg
    Hi, you're link is wrong. Anyway, I like it! just the bump is to exaggerated so it looks like old beaten up / scratched plastic.
    Banned OnlineRender's Avatar
    Dec 2008
    Glasgow , Scotland , UK
    6,358
    great texturing ! only thing that throws me is the glass / black on the top of the model...other than stunning
    "OH NO!", Joseph Joestar ncr100's Avatar
    San Francisco
    1,100
    Blog Entries
    2
    Phatt!
    -Nick
    audio: Ö ¤ wk Py
    looks good, small pieces of litter, rocks etc. on the ground maybe
    the detail is very nice, but the render looks a bit flat...
    Registered User Bliz's Avatar
    Dec 2003
    London, UK
    280
    What would sell this image a bit more would be to spend some time cutting in real geometry on the ground plane.
    i.e. model that drain cover that is present in the texture and make it a bit lower than the surrounding concrete. Model each slab of concrete and vary their height and rotation ever so slightly.
    Then you'd have some light catching the details of the floor which would break the 'ice rink' flatness of the current floor plane.
    Cheers,
    Bliz::..
    My homepage
    www.anthonyrosbottom.artstation.com
    some tricks to make it less flat,...
    HRDI
    AO
    sRGB
    tonemapping (or curves)
    glow / lensflare
    bleach bypass effect
    sss for the tyres +more dirt, less specular
    camera distortion
    window reflection (some use fake reflection, often works good)
    noise (in dark areas)
    chromatic aberration
    color correction / gamut warning correction
    how many samples are used in the GI setting? (10 would be good)
    p.s. try to not use blurred clouds
    added some of the effects, (exaggerated) >
    (attached .psd)
    sorry, just got carried away here... 
    Attached Files Attached Files
    just realized something when it comes to the surfacing of this vehicle.
    if the body is made out of plastic, it should be glossy too.
    if the body has car paint, it should have rust.
    Cow Orker cagey5's Avatar
    Manchester UK
    3,268
    Maybe it's some form of alloy.
    Forum Tips
    If English is your first language, you should know it's 'losing' and not 'loosing'!
    Just couldn't help it. Post in After Effects.
    Win 7 64, Core i7-3930 @ 4.2 GHz, 32 GB RAM, GeForce GTX 680
    http://www.ryste3d.com
    Really nice design! But without postwork looks like unfinished and a bit flat.
    The cockpit glass need reflections for give a more rounded shape to the vehicle,and the ladder is too much high for a human scale.
    I wouldn't use too much blur in post.The blur smooth the hard edges of the vehicle.I would use it only on the backdrop to give more depth to the image.
    Just my 2 cents
    Forgot... maybe for more image balance you could add more sky!
    Its just me, but I like the original render best... I feel the renders below add too much light to the scene and get in the way of the effectiveness of the image. I do agree rust is needed, but it looks like the vehicle could very well be made out of a material other than metal and still work. I do agree the ground plane is rather drab compared to the rest of the scene. Maybe cheat and use another, larger bump layer to simulate height variance of slabs? That, and maybe something for the black window of the vehicle as well, it doesn't share the detail of the rest of the image... I imagine some of those scratches/wear from the body would have made it to the window.
    Quote Originally Posted by chazriker View Post
    I totally agree with you. I also like the original render better.
    South Yorkshire, England
    2,500
    I'm with them, I think the first render is excellent... apart from ground plane and bump comments above. Just a little reflection on the glass and you're done.
    On a funny note, when I first looked at it from distance (and the thumbnail) it looks like a Jabba the Hut Smart Car, lol.
