Thread: Free model of concept MPV
    May 2003
    295
    I hope You will find some use for this model. I finished it just few minutes ago so scene setup ( included ) is rough. I hope You will post here some renders if You find some nice background for my car.
ID:	101501   Click image for larger version.
ID:	101502   Click image for larger version.
    Attached Files Attached Files
    Dec 2009
    40
    ciekawe jaka grupa docelowa dla tego pojazdu - rodzinka, biznes, czy weekendowy wyjazd na ryby
    Bardzo fajny pomysł i sama idea
Name:	Q06 nR cars .jpg
    tak na szybko maly KV
    SUPER! dzięki za MODEL!
    I'm a Registered User monovich's Avatar
    Rocky Mountain High
    1,526
    excellent!
    I might just give it a go. Will post here if I do. Cheers!
    Mike, in Monsters Inc Tartiflette's Avatar
    Montpellier, South France
    596
    Cool model, thanks a lot for sharing !
    I thought i could give it a try with a scene i had set-up some time ago with cars from Nigel Schutte, scene which was making extensive of the free backplates and HDRI found at HDRI Locations (great place to find professional quality backplates for car rendering or whatever, and a big thanks for the free backplates on the website ! ).
    As my scene was already setup, i just had to change a little bit the surfaces to match what i had previously with the other cars, and "voilā" !
    There are still a lot of small things here and there that would need to be changed or arranged, but as i didn't have that much time to play with this car (unfortunately as it's really a great model !), i think it will be good enough for just a test !
    Again, thanks for sharing the model, very generous from you.
    Cheers,
    Laurent aka Tartiflette
    P.S. : renders straight out of LW11, no post-process at all, just rendered and saved as sRGB...
Name:	Concept-Car MPV 01-01.jpg
ID:	101664   Click image for larger version.
Name:	Concept-Car MPV 01-01b.jpg
ID:	101665   Click image for larger version.
Name:	Concept-Car MPV 01-02.jpg
ID:	101666   Click image for larger version.
Name:	Concept-Car MPV 01-03.jpg
ID:	101667   Click image for larger version.
Name:	Concept-Car MPV 01-04.jpg
    d powerfull Of lightwave abdelkarim's Avatar
    Nov 2008
    algeria
    758
    u need to make black shadow from area light make ur ground black and alpha channel u choose shadow density and u drender export it in any program ps like combstion ex.. .
    u did great job . i hope too see final render with this things .
    Cheers
    nice model Fazi, thanks
    Heffalump
    Away
    3,897
    Thanks!
    Inactive.
