Thread: Sea Texture
    May 2010
    Norway
    305
    Sea Texture
    I've been trying to recreate this http://www.batmagasinet.no/baatweb/mm.nsf/lupgraphics/Vicem_Vanguard1_470300.jpg/$file/Vicem_Vanguard1_470300.jpg - using only the sunsky plugin for LW.
    So far I've failed pretty hard.
    Anyone know a setup in order to get a similar results?
    My settings now are just a floor with a turb displacement and some bump with a fresnel effect.
    Then messed arrowned with brightness and saturation on the sunsky.
    PS, is this a bug or is it suppose to be like this, if I dont apply the sunsky modifier to adjust to realistic lighting dependent on the time. Doesn't matter if I change the color of my light to red or green. The color is entirely affected by the backdrop? The only thing the light controlls is the intensity?
    Jesus Christ died for you =)
    Sep 2005
    Earth
    3,121
    You should use the Houdini ocean shader for lightwave. Found here:
    http://www.cglounge.com/plugins/hot-...kit-lightwave/
    May 2010
    Norway
    305
    Quote Originally Posted by 3DGFXStudios View Post
    Thanks! I'll check it out.
    May 2010
    Norway
    305
    Uhh, just curiouse does there come any color shader? I got the displacement map to work great, but I'm cant seem to locate any color shader.
    Sep 2005
    Earth
    3,121
    No there's no color out put that I know of. But you can check this forum the HOT ocean forum for examples. I remember that Lino made one. Just search for HOT ocean and you'll find the thread.
    May 2010
    Norway
    305
    Thanks though this is awesome and maaan save so much time! Don't even need to animate the ocean.
    You dont have any more of these magix hidden up your sleeves eh? hehe
    May 2010
    Norway
    305
    Is there any way to change the speed of the waves only way is lowering the frame rate in a post program?
    "Wind Speed" only change appreance hmm
