Thread: Image Sequence Saving???
    Michael Nicholson zapper1998's Avatar
    spokane washington usa
    4,663
    Blog Entries
    1
    What is the preferred Image format, for saving Image Seqeunces?
    Tga32
    Tga24
    Png24
    Png32
    or ???
    I then load it up in QT save it as a .Mov..
    And Also save it out as a Win Media format...
    Intel Core i7-980, OC 4.7ghz water cooled.
    Gigabyte x58-UD3R with an Intell SSD 180GIG
    RamCorsair-DDR3-1600-32GIG
    Nvidia Titan Z, x 2 And 1 GTX-1080 by Gigabyte.
    4xEnterprise/WDVelociRaptorŪ300gig
    Oct 2003
    Orlando, FL
    4,143
    I use TGA. Many use PNG. I often use JPG just for the preliminary and tests.
    The 32 is only of use if you are using the Alpha.
    If you are not using solid colors a first generation jpg is pretty much artifact free, so it is a viable solution if you are low on space. If you need higher quality or alpha channel then PNGs have loss-less compression so I see no reason to use TGAs.
    Sep 2005
    Earth
    3,121
    OpenEXR Float32bit with or without EXRtrader. Great for comping purpose...
