Thread: newb qn - saving preferences
    can't.. re.. member stib's Avatar
    [0,0,0]
    958
    I don't want to reinvent the wheel: is there a standard sort of routine for saving the last used parameters for a script?
    I have a simple generic script with about a dozen possible parameters for the user to play with. I hate having to type them in every time, so I was thinking about having the script load up the last used values from a file. Is this the way to go?
    If I use a file, where is the best location for it? I'm using OSX, but would like to make it cross platform, just for the sake of doing it well. I'm thinking a file in the plugins folder maybe? Is there a method for getting the path to the LScript that is being executed?
    Oh while I'm here: another newb qn: can you add an LScript to the Layout menus?
    Thanks, I'll get out of your way now.
    original member fxnut's Avatar
    Pinewood Studios, UK
    225
    Re: newb qn - saving preferences
    Yep, you want to have a look at the Store() and Recall() commands. They do exactly what you're after.
    Regards
    Andy
    [0,0,0]
    958
    you ripper. thanks.
