Thread: render wireframe options
    Plays with fire sadkkf's Avatar
    Outside looking in
    1,206
    Hey--
    Are there any options (other than color) for rendering an object in wireframe?
    Maybe I'm approaching this wrong, but I've changed the Render Mode to Wireframe and it's great, but I'd also like to add a transparency gradient to it so it sort of draws itself from one to the other. Problem is, that doesn't work.
    Any thoughts?
    So much water, so few sharks.
    "...all men are created equal." -- US Declaration of Independence
    Nov 2006
    Burbank, California USA
    4,576
    You could render two passes of your object, one normal and one wireframe, and do the transition in a compositing program.
    Profile piece
    2010 Reel
    'The X's' Reel
    Aug 2010
    Kernow
    2,057
    You can use a null to set the area you want to be draw with wires. I have also added some transparency to it.
    Gives :-
    http://youtu.be/TA5cIjOa-Uc
    Attached Files Attached Files
    Outside looking in
    1,206
    holy crap. That's pretty cool, XswampyX.
    @nickdigital -- I'll be sweetening the anim in after effects anyway, so a quick composite is easy enough. Thanks!
    Outside looking in
    1,206
    @XswampyX - where did you get the dbwRemap plugin?
    Aug 2010
    Kernow
    2,057
    From here :- http://www.db-w.com/
    Under db&w tools. Lovely!
