Thread: Turning off AA?
    Dec 2009
    UK
    76
    Turning off AA?
    LW10 ( yes I should upgrade to 10.1 but busy :P ) and I need to switch off AA on the render...
    I'm rendering out map tiles for a 2D game, which are perfectly sized and rendered but the renderer is blending them with the background (each tile is rendering out separately) which means lines in the game when I put the tiles together.
    I can scale a bit to overlap the tiles by a pixel but that just seems nasty.
    Any way of turning the AA off or making the alpha channel binary or some other trick?
    Thanks,
    Deano
    Wouldn't you be referring to a render done with "unpremultiply alpha"? The choice is under the output tab in Render Globals.
    Mar 2004
    Derbyshire, UK
    3,127
    Make sure you use a 32bit file format which will save the alpha out with it - 32bit PNG files work nicely.
    Washington State, USA
    2,880
    Image Processing>Add Image Filter>Spriteedger
    might be what you're looking for.
    Profesor Pixel Poo Mr Rid's Avatar
    Oct 2005
    Los Angeles
    2,792
    AA should be off when using Perspective camera with Classic reconstruction, and no Adaptive Sampling, oversample or Soft Filter. Usually you want to render with a black matte background.
    If there are BG objects or colors tracing, sometimes it is easier to simply drop a black card just behind your FG object and set it's properties to Matte and to not affect tracing.
    "O K, so what's the speed of dark?"
    Demo reel 2017
    https://www.youtube.com/watch?v=yOOixvRhcs4
    Dec 2009
    UK
    76
    Thanks for the help
    unpremultiple alpha and sprite edger are both new to me and very useful!
