Thread: Latest Nvidia drivers creating problems.
    Is anyone else noticing that the latest Nvidia drivers are creating problems?
    The strangest problem is in Dual monitor mode (Horizontal span) the second monitor has an area in the bottom right that if you move any objects over to it they lock up and will leave a trail. We moved a VT vision window over to it and the video playing froze and if you moved another object or window over it the object or window left a trail.
    I am also finding that in single monitor mode the video locks up occasionally. You can usually get the lockups to happen if you have both Aura and Toaster CG open together for a certain period of time. After which you will get a VT[3].exe error and VT[3] will shut down.
    Dec 2002
    San Antonio, TX
    3,830
    There's been another post along these lines, yes.
    I'd suggest you go back a version.
    Don't stream it - TriCast it!
    Amused
    Keeping Austin weird
    1,322
    I just installed 45.23 two days ago, and it seems to work fine. Before, the Graph Editor would crash a dual monitor setup. There's a driver listed specifically for Lightwave that is also specific to certain cards, but 45.23 is the generic.
    TW
    45.23 is the version that is messing up.
    We've got it simple. Jim_C's Avatar
    Thee cool evening breezes of Anytown, USA
    4,028
    Yes, i have had problems with 45.23 that rolling back to previous solved. I have heard the same from one other person.
    Driver problems also.
    I went back two versions which solved all problems. The worst problem I had with the latest version and spanned dual monitor setup was, when the toaster card kicked in and would start to show up on the NTSC out the system would reboot. : (
    Jennifer & Ronald Tigges
    videocreations.com
    [email protected]
    been flying since .9
