Results 1 to 12 of 12
Thread: Loading Scenes and Expressions with LScript
    Jun 2006
    Virginia
    51
    I know you can load items from a scene using "LoadFromScene", but can you restrict what gets loaded from that scene? For instants I do not want the lights. Can anyone point me in the right direction? Also, is there a way to load an expression file with LScript (and assign them to the correct bone too)? Thanks for any help.
    Ross
    Jun 2006
    Virginia
    51
    So, I'm guessin' the answer is "no".....
    mucho mojo nikfaulkner's Avatar
    brighton,uk
    315
    i think its a "no" although there was some way to parse scene data (including expressions) into a scene with lscript. i found it on here somewhere a couple of years back.
    yeah alright.... we won a BAFTA http://littleloud.com/work/bsr/
    Jun 2006
    Virginia
    51
    Thanks, I found some of what I need!
    LoadFromScene is a tricky one, it doesn't always behave in a script. There is another sibling, though:
    Code:
    @version 2.7
    @warnings
    generic
        AutoConfirm(true);
        CommandInput("LoadElementsFromScene 4 E:\\myPath\\myScene.lws");
        AutoConfirm(false);
    But for the longest time you couldn't actually suppress the user dialog where the user can actually choose things, which makes the entire method somewhat flawed. That's what the AutoConfirm is supposed to be for, not sure if this is still ignored in this context.
    The general safe method instead is to write the current scene to disk with "SaveSceneCopy", re-open it as file object, hack it, and load the full thing.
    But for expressions you don't really need that. Here is a little Master script example I found, can't remember where, that attaches an expression to the selected object. The critical parts are CreateExpression() and AttachExpression().
    Code:
    @version 2.2
    @warnings
    @script master
    @name Expression Test
    Hello,
    If you run attached script you may get that expression
    thing working... It's a master class script. Run it
    and press 'Add expression' button. Then expression
    would be created and attached to the Camera Position X
    envelope...
    regards
    Darren
        script_name = "Expression Test";
        exp_name = "test";
        exp = "[Light.Position.X]/2";
        exp_exp;
        c0..10;
    create
        setdesc(script_name);
    destroy
        if (reqisopen())
            reqend();
    flags
        return(SCENE);
    process: event, command
    load: what,io
        if(what == SCENEMODE)   // processing an ASCII scene file
    save: what,io
    options
        reqbegin(script_name);
        c2 = ctlbutton("Add Expression",130,"add_exp");
        reqopen();
    add_exp
        com = string("GE_CreateExpression ",exp_name," ",exp);
        CommandInput(com);
        com = string("GE_AttachExpression ","Camera.Position.X"," ",exp_name);
        CommandInput(com);
    Super Member dblincoe's Avatar
    Aug 2004
    Springfield, Missouri
    816
    You do know you can exclude the lights and the camera when using "load from scene". If the check mark besides it is greyed out it won't import, if it is highlighted then it will. You can select any object, light or camera.
    Of course, you may be after another way. I just thought I'd make sure you knew that so you were't chasing something you already had.
    Yes, of course. I was strictly talking about automating this Load From Scene selection process in the context of a larger script. If the script is a batch process or does additional setup steps with the loaded items, it may be necessary to bypass user interaction.
    It gets a hell of a confusing when an "AutoSetup Insanely Awesome Character Rig" script comes with instructions to "Please set a checkmark for all Bone Items on the LoadFromScene dialog that pops up half-way through the setup process, and make sure to uncheck the Camera otherwise this script may overwrite your current Camera animation."
    Aug 2004
    816
    Quote Originally Posted by Blochi View Post
    Gotcha.
    Sydney
    8,273
    You could go through the lights before load from scene and see how many there are, then laod from scene and clear out any extra lights....
    Jun 2006
    Virginia
    51
    Thanks for the info everyone...
    Jun 2006
    Virginia
    51
    Is there a way to make LoadFromScene import the Master Plugins by default? So, I can still use AutoConfirm(false) and I will get ther master plugins.
    Thanks,
    Ross
    Aug 2004
    816
    Regarding the lights...I've also renamed the original scene lights something like "delete me" or "kill" then in the new scene used the object filter to search for that prefix on the lights and deleted them.
