Results 1 to 9 of 9
Thread: Grooves.
    Registered User bracki7's Avatar
    Mar 2009
    107
    Grooves.
    Hi there
    So, I continue my fight with plastic bottle. I have to do plastig bottle with grooves it can't be made by lathe. I don't know other way. only lathe or bump. So I choose bump. I tried and tried with bump and... result below.
    It's not bad but my brand manager still don't like it.
    Below is her reference:
    Of course I mean grooves.
    First both was made by using bump. The last one I modeled. But it was easy because I can used (lathe).
    I know, I should try modeled that or try with displacement map but I don't know how.. Maybe there is some option to make visible grooves on the back side of bottle by bump. Is the possible?
    Any one can help me? Probably by finding for me some tutorial about bump or displacement map or maybe about other way to do something like this ?
    Any help is very ..e.. helpful
    ps. Partly it is the same object, with the same setup for plastic, air, fluid etc. For first two I addition used reflection and refraction spherical map with hdr.
    But that something is obvious does not mean that it is true.
    7,876
    I would use TrueArt's Wrinkle http://wrinkle.trueart.pl
    which is available alone, and together with TrueArt's Modeling Pack http://modelingpack.trueart.eu
    Mar 2009
    107
    Ok, I saw on this webpage. Look's nice but there were only simple shapes. Can I use some ..hm.. like in bump some map for make a grooves?
    7,876
    For making bumps there is another TrueArt's Modeling Pack tool TrueBump http://truebump.trueart.pl
    You can paint bumps on geometry using Airbrush.
    Dec 2003
    Portugal
    1,819
    maybe you can subdivide the bottle a lot and in the deform tab in object properties select
    "enable bump" and give it some value.
    Mar 2009
    107
    Sensei, there is any demo of this plug-in? I mean TrueBump?
    Axes grinder- Dongle #99
    Seattle
    14,726
    What exactly is she objecting to?
    Praise to Buddha! #resist
    Mar 2009
    107
    For she, the backside grooves makes transparency in this bottle (I mean in third bottle). Maybe grooves in my new (first two) bottle will works in the same way under condition, that they will be part of surface (now they are bump).
    Dec 2003
    Portugal
    1,819
    what I also see are the blurred refractions on your bottles. That doesn't help to make it look more like the reference. Maybe you're using a blurred background.
    In the reference I can see the grooves in the back and in yours we can't.
