Thread: Market hall exterior.
    Newbie Member Mruk's Avatar
    Nov 2010
    Wroclaw, Poland
    33
    Market hall somewhere in poland. Render LW internal, some post in GIMP.
ID:	95853   Click image for larger version.
    Overall you have some pretty nice renders there! Most of your materials and textures look really good! I just have a few little critiques that may help improve your renders.
    - I noticed some of the parking lines appear to be casting a shadow.
    - I also noticed that the shift camera would help your renders by keeping the vertical lines on the render straight. Although this is more of a personal preference and I usually only use it because clients sometimes get confused about the sloping vertical lines due to perspective.
    - Looks like you may have just a bit to much warping on the glass for the reflections.
    I also do these kind of renders all the time and there always seems to be little things that can be picked out and tweaked that I never notice until someone else looks at the render and points them out to me.
    Nov 2010
    Wroclaw, Poland
    33
    / I noticed some of the parking lines appear to be casting a shadow.
    True. Parking lines are geometry taken from fbx and not corrected by me.
    /...shift camera would help your renders
    I didnt even think about this, but its interesting.
    /...a bit to much warping on the glass for the reflections.
    Its arbitrary, but next time i will propably uv map bump deformations for each glass plate indepedently.
    Another task for me is realistic trees. I have lack this kind of assets. So, thanks for your opinion
