Results 1 to 12 of 12
Thread: UV Map to Photoshop
    UV Map to Photoshop
    I'm looking for a plugin to take a UV map and convert it to an image for texture creation in Photoshop.
    I tried uvimaginator plugin but it does not work on my system (Mac OS 10.6.7, Lightwave 10). I'm hoping there's another plugin out there that will do it. I can't believe in this day and age we have to resort to lo res screen graps.
    Thanks in advance.
    Oct 2003
    Orlando, FL
    4,143
    Screen grab sure, but why does it have to be lo res?
    Dec 2003
    Portugal
    1,819
    man...if you just read the manual...lightwave 10 modeler manual page 267
    From the manual:
    "Once you have a UV Map and are ready to paint it, don’t
    make a screenshot, which will be of poor quality at best, and
    will need to be manipulated before you can use it. Instead,
    go to File > Export >Export Encapsulated Postscript,
    choose Texture UV from the View field, and make an .eps
    file, so you can have clean, high-resolution maps."
    NewTek documentation wrench's Avatar
    May 2010
    Pessac
    909
    And that's been in there since at least LightWave 6.5. The only possible downside to it is still that it doesn't "do" curves so if you want to export a UV map for a SubD object, you'd be better off freezing it, exporting the EPS then undoing until you are back to SubDs.
    B
    LightWiki
    Machine spec: Phenom II x6 3.3GHz, 8GB RAM, Windows 7 64-bit, NVidia Geforce 450 GTS 280.26
    7,876
    Quote Originally Posted by PaddyO View Post
    Yes, there is VMapManager tool from TrueArt's Modeling Pack http://modelingpack.trueart.eu
    With it you can also load and save vertex maps (like weight maps) to/from image file, so you can export them to use in any other application.
    I know what you mean, and I can't be a real help for you either (since you are on a mac), but for those win users out there:
    http://www.splotchdog.com/index.php?...d=61&Itemid=39
    I consider it as one of the most valuable plugins I ever released in terms of productivity enhancement.
    chris
    Dec 2003
    Portugal
    1,819
    tischbein3, that one seems really nice. but I still don't understand what's the problem on exporting the uvs as an eps file...I think its quite perfect. you simply export the uv to eps (like I said before) and you can import the eps in photoshop in any resolution with perfect antialiased lines because it's a vector format.
    Well all IMHO. since this is a workflow question
    Speed, less button clicks, less files (and their locations) to care of.
    Defining the resolution while I can see it inside modeler (without any dpi calculations)
    And as a bonus, Ctrl V in photoshop also provides me a comfortable way to quickly swap
    out an existing map layout with a new ones
    Overall it takes out (for me) a lot of these small slowdowners, and therefore
    increases not only the speed, but also my willing to use them more extensively, or to reedit them at later stage
    I guess the opinion on this is very much related to -how- and -when- you do your uv mapping.
    @erikals
    Nice tip / alternative (and even for mac)
    Just tested tischbein's and it works great but does not support subpatch interpolation so I am stuck copy pasting for now unless some of the others support it?
    7,876
    Non support sub-patches, because LWSDK doesn't allow it.
    You must use ctrl-d to freeze mesh prior rendering UV map.
