Results 1 to 15 of 17
Thread: Importing animation from blender
    I found an engine model on Turbosquid that I could really use for this job and it's even animated, the problem is that it's a .blend file. Anyone know how to get the animated model out of Blender into LightWave? I've tried using collada, which sort of worked, but the model was rotated (Z up problem) and some of the animation didn't quite rotate properly, probably the same Z up thing I'm guessing. FBX didn't work at all, after loading the LW scene only had a null.
    Even if I can't get it animated second best would be a way to export the model from Layout to Modeler with all of it's parts in the correct positions, When I tried this before all of the parts got moved to 0,0,0 I think I've seen a plugin that does this before. I know blender can save out an LWO but I got an error when I tried to load it into LW. Any ideas?
    ~~Phil Nolan
    How Old? Really? Aww Heck colkai's Avatar
    Staffordshire
    7,806
    Yep Z up is the normal problem, same when handling OBJ & 3DS files. Most other packages see X/Y as the 'floor' and Z as up, so the only thing I can thing of, which isn't elegant, but I've done it with MotionBuilder stuff, is to select all items, select all curves and shift them in the graph editor by 90 degrees. Or alternatively, parent everything to a null and then rotate that.
    Dirty, but it can work.
    Too old to die young.
    I actually tried the null thing and it didn't work for some reason. The objects all jumped to different positions / rotations as soon as I touched the null. I'll see what I can do in the graph editor, thanks.
    ~~Phil Nolan
    Washington State, USA
    2,880
    Could you bake the animation to an .MDD? I don't know if that would work or not.
    Hmm... I'm not sure, I don't use .MDD much. Plus I'd rather it be editable later if possible, in case the client asks for changes.
    ~~Phil Nolan
    Running at 29.97 fps Titus's Avatar
    Mexico City
    2,839
    Quote Originally Posted by Philbert View Post
    We work with LW and Blender, if you find a solution please be kind to share it .
    I did note one thing, that when I load the exported Collada file it has a Motion modifier on it called RotationOrderConverter. I'm not sure what it does though.
    ~~Phil Nolan
    Professional amateur Amurrell's Avatar
    Dec 2005
    Lincoln, NE
    1,350
    I've seen others rotate the model in Blender 90 degrees which ever direction it needs to go before exporting so when they import into their app it is the right direction. Have you tried that?
    --Andrew
    Bono Animo Esto
    Intel Core i5 3570k
    nVidia GTX 970
    8GB DDR3 1333MHz
    Windows 10 Pro 64bit
    As for blender 2.5 and lw 10.0, I didn't checked this method myself, but
    it might be worth a try:
    Try export via fbx, do _not_ use a parent null since lw will already do this.
    Pay attention that blender will put the rest keypose on frame 1 and not 1,
    so the first frame might look a bit weird.
    Quote Originally Posted by Amurrell View Post
    No I haven't, that makes sense actually.
    Quote Originally Posted by tischbein3 View Post
    Thanks I think I said above, I tried FBX and all I got was an empty scene with a null, nothing else.
    Edit: wow rotating in blender actully worked, well at least it's facing the right way, the animation is still wonky, but I'm just happy to have a working model.
    ~~Phil Nolan
    Missed that, sorry.
    Could you pm me the blend file ?
    nowhere
    241
    go with blend 2.49, you can export selection like a simple obj.
    2.56 scripts have some rotation problems.
    Carlos Puebla
    //TD 3d Character Artist.
    ncpuebla (arroba) gmail dot com
    nowhere
    241
    for animation you can go with mdd. only in 2.49. in this case probably you can need to use separate pieces.
    Carlos Puebla
    I've got the model exported fine now, thank you. It's just a shame I couldn't save the animation. I also did have to flip some objects by 90 degrees. I do wish I could save out all of the objects in the scene as one LWO file though, the Collada conversion left me with 30 objects for this engine.
    Like I said earlier I would prefer to avoid baking the animation in case my client needs me to change it.
    ~~Phil Nolan
    Ok this might be interesting for everyone there actually two actually two solutions wich seems to work:
    Solution one:
    - Using blender 2.49 fbx export, with the settings as seen in the attachment.
    Solution Two in 2.5:
    For whatever reason this seems to work only as for lw 9.6, and the latest blender builds (graphicall) . lw10 does only import fragments of the animation data
    - Parent all objects to a Null/Empty in Blender (at 0,0,0 no rotation)
    - Export Data as Collada
    (according to the log, they did some fixes in the last few days)
    As for the last I've actually unparented some stuff inside Blender, but I don't know if this had really some impact on this.
