Results 1 to 11 of 11
Thread: LIghtwave Shift cam
    LIghtwave Shift cam
    i need a camera like LW's Shift Cam but without its extremely annoying geometry clipping (in case some didnt notice -i.e. NT - that camera clips geometry near or far from camera, depending on P angle and on grid size, so often it's impossible to see the whole scene at once).
    I wonder if there's one around (Perspective Control camera is not an option since it's 32 bit only) or if someone can code one (paid work).
    thanks,
    Paolo
    I thought the ubercam plugin offered shift functionality, but now I can't find it.
    Also interested in this.
    Model: MacBook Pro 10.6.4 - 2.66 GHz - 4GB - NVD GF GT 330M
    Render: Win7 64 - Core 2 Quad Q9550 2.83GHz - 8GB
    NewTek Developer jameswillmott's Avatar
    Dec 2004
    Gold Coast
    3,171
    The built in shift camera should do what you want without OGL issues, turn off Use Cam Pitch and set vertical shift manually using the spinner.
    LightWave3D training, assets, news and discussion at www.liberty3d.com
    My opinions are my own and do not represent the opinions of any other entity, Liberty3D is not officially endorsed by NewTek.
    Eh, what?
    Right here, right now
    604
    Quote Originally Posted by Pavlov View Post
    Changing the "fixed near clip distance" value in display properties doesn't do the trick for you?
    ADP.
    hi James, i know but this has worse key-ability while animating (setup a slider etcetc). Would be lovely if even P option was fine. Again, it seems that Shif Cam crashes on LWSN (so i was told by a renderfarm - not tested by me) - is there any workaround ?
    Alexos - yes, clip distance solves it sometimes, but not in every scene. In some cases you cant see scene correctly.
    thanks,
    paolo
    Dec 2004
    Gold Coast
    3,171
    The crash has been fixed, not sure in what release you'll find it though.
    nice !
    While we wait for the release, do you think if it's possible to update current .p for those who still use 9.6 ?
    bye
    Paolo
    Registered User Keeks's Avatar
    Oct 2010
    Silicon Valley
    19
    Quote Originally Posted by archijam View Post
    The ubercam Radial Shift Camera will be able to do this. It has controls for horizontal and vertical shifts and skews as well as lens distortion. If the lens distortion controls are set to zero, then it is like the perspective camera with shift and skew controls.
    Kiko
    Liberty3d.com
    Banned OnlineRender's Avatar
    Dec 2008
    Glasgow , Scotland , UK
    6,359
    slightly offtopic however photoshop Cs6 beta has tilt shift and its a free download just in case you are still stuck
    A shift is optically the same as using a wider lens and cropping off center. So you could always do that if you want a shift. Now if you want a tilt or swing that is a different story.
    If I want to duck or dive, or maybe shimmy, what are my options?
