Thread: Move values from one texture channel to another?
    Registered User Dreamcube017's Avatar
    Jun 2010
    Ohio
    305
    Hi guys.
    I've imported an object that has a LOT of different textures in it.
    The textures were all gathered from a .mtl file. The problem is that all the textures popped up in the color channel and not the deffuse channel so they don't show up. (The textures are images)
    I would just reassign the images to the deffuse channel manually, but the problem is that there wer a LOT of images, and when I go to select one, they are all out of order. Lightwave doesn't seem to list the images in any kind of order, so it makes it really hard to go through the list in the dropdown menu and find them.
    I know this sounds kinda confusing, but can anyone help?
    Thansk.
    If its in the color channel you should see them fine. They should just load and you should see them.
    Nov 2006
    Burbank, California USA
    4,576
    You can multi-select layers and do a copy/paste all layers in the Surface Editor.
    Profile piece
    2010 Reel
    'The X's' Reel
    Jun 2010
    Ohio
    305
    Ah ok thanks. They do show up now I see them. They don't show up on the shader ball though.
    Is there some kind of eye dropper tool that I can select the specific material off of the object, because sometimes the shaders are named oddly and it'd be much easier to pick them if I could just select one of the materials with some sort of eye dropper tool.
    Thanks for replying.
    Registered User speismonqui's Avatar
    Jan 2008
    Panama
    519
    you could use VIPER (F7). Select the object and it jumps to its material.
    Dell XPS8700 Quad Core i7 [email protected] - 16 GB DDR3 - GeForce GTX 750ti - Windows 10
    Jun 2010
    Ohio
    305
    Thanks, but the object has MANY materials.
    It's basically a structure that has over 20 matials on it.
