Thread: extrude and taper?
    extrude and taper?
    I'm trying to make a whip for a model. The whip is being carried in his hand. The thing is, its rolled up, and its also tapered as it extends to the end, starting out at about 2 inches at the base, and gradually going down to about an eighth inch at the tip. My question is, how can I do the extrude and taper at the same time? Is it possible, or will I just have to make the whip, and then roll it up after it's uv mapped?
    Oct 2003
    Orlando, FL
    4,144
    There is a function that does that already called Magic Taper (I think...something like that)
    Thanks, I'll chek it out
    Nov 2006
    Burbank, California USA
    4,576
    Instead of rolling it up in modeler you could roll it up with bones in Layout. This way if you need to adjust the model it's easier to do it on a model that's straight. Plus posing it will be easier.
    Profile piece
    2010 Reel
    'The X's' Reel
    NewTek documentation wrench's Avatar
    May 2010
    Pessac
    909
    MagicBevel is the tool in Modeler.
    B
    LightWiki
    Machine spec: Phenom II x6 3.3GHz, 8GB RAM, Windows 7 64-bit, NVidia Geforce 450 GTS 280.26
    PX_Bezier might be nicer then Magic Bevel, since you can save the path and tweak it later and you work with beziers, so, less control points.
    I can't figure a way to make the plugin to pick an existing spline, wich i think, it's a shame.
    To pick an existing spline and control the tapper falloff there are ways... but maybe a bit overcomplicated.
    One could be to make a uv for the profile, use Rail Extrude with 'Make UVs', Run UV2Weight to get a weight map along the whip. Then make a morph and 'Point Normal Move' to make it the least thin. Then in Layout get some nodes like the image below to make the whip taper according to the weight map (Curve node for falloff control).
    Cheers
    Thanks Probiner,
    Thanks for your help, it is much appreciated, but honestly, what you propose is waaaaaaaaaaaay too complicated for me! I found out that in blender, you can make the whip with a spline,and then just scale it down towards the tip. Yu have to convert the spline to polys, and export it as obj. So that's what I did. What I will do is try and use the px bezier plugin next time, just to see if it can be done in Lwave.
