Results 1 to 13 of 13
Thread: Render Times Progressively Increase
    Waver since 6.OMG
    Jan 2009
    North of the Equator
    46
    I have a small scene with a one charactor with minimal rigging and minimal movement. Every frame that renders is longer than the previous frame. Within the span of 5 to 6 frames times will go from 25 seconds to over a minute per frame. After rendering 200 frames in a sequence, render times for these ~20 second frames are 20 minutes.
    W - Xeon E5420 @ 2.5, Win Vista 64
    H - i7 2600k, 16GB, Win 7 Pro 64
    LW 11.x
    Does the scene have radiosity enabled?
    Cheers
    Tomek
    GarageFarm.NET
    The Cheapest Render Farm - 10,000 cores and growing!
    Skype: garage.farm
    Waver since 6.OMG
    Jan 2009
    46
    Yes.
    LW 11.x
    I am not sure try again w/o cache (there is a chance that you cache file grow up to something like 3GB and it takes forever to write/save to this file - have a look) and/or w/o Use Behind Test.
    I would have to check in the manual but I don't really have time ATM, try checking out here: http://www.except.nl/lightwave/RadiosityGuide96/
    I hope that will help!
    Cheers
    Tomek
    GarageFarm.NET
    Skype: garage.farm
    NewTek documentation wrench's Avatar
    May 2010
    Pessac
    909
    Reduce the frame step for the radiosity cache as well - make it cache every 5 or 10 images rather than every single one (if you do want to keep it on), and make sure you read Tom Bosschaert's excellent guide to get to grips with how to get the best from LightWave radiosity: http://www.except.nl/lightwave/Radio...de96/index.htm
    B
    LightWiki
    Machine spec: Phenom II x6 3.3GHz, 8GB RAM, Windows 7 64-bit, NVidia Geforce 450 GTS 280.26
    normally i am different ingo's Avatar
    Close to the baltic sea, nearly in it
    1,904
    wow, 32 secondary bounce rays, thats pretty high, do you need it ? i usually start with 10 .
    ingo erik moltzen - virtual image maker --- www.im-graphics.com
    Shouldn't you be using *anim* cache? Your render times will get longer, but it's designed to remove flicker that you get when using interpolation. Using the non-anim cache with an animated character will probably show some artifacts.
    Confirmed -
    Waver since 6.OMG
    Jan 2009
    46
    Thanks all for the responses. I will try these suggestions.
    LW 11.x
    Quote Originally Posted by toby View Post
    Only if stuff in the scene is moving (anything except the camera).
    Cheers
    Tomek
    GarageFarm.NET
    Skype: garage.farm
    Quote Originally Posted by Soth View Post
    Obviously. He did say he has an animated character.
    Confirmed -
    silly me
    Cheers
    Tomek
    GarageFarm.NET
    Skype: garage.farm
    The cache is useless with deformed characters.Turn it off. The cache anyways is buggy, it does exactly what you described. We rendered 2000 frames sequence and after a while the render time per frame was ridiculously high. Others also complained about this hidden feature. I try to avoid using it.
    Quote Originally Posted by bazsa73 View Post
    Yea I couldn't get anim cache to work, but I thought other people might have - I ended up using a low-res gi solution combined with enough (classic) motion blur passes to eliminate flickering.
    Confirmed -
