Thread: Is there a way to clone an object with expression attached to it?
    Registered User Dennik's Avatar
    Winston Salem NC
    202
    I'm having a hard time cloning objects without messing up the referenced names in the channel expressions. I have to manually go in there, and make a clone of the expression and fix the names.
    Is there a way to do this automatically? Otherwise it defeats the purpose.
    automator of tasks xchrisx's Avatar
    Nevada
    593
    Blog Entries
    6
    depending on what you need to do, can you use an intermediary object for the expression. For example, use a null in the expression as a control rather than the object's name, then manipulate the null as a controller? If you need to make each of the expressions unique to a specific object, then you might try Relativity as it supports a SELF option that LW expressions do not.
    My Lscript Collection | LinkedIn
    3D Generalist IGT
    Winston Salem NC
    202
    Relativity would be a good idea! The self option is what I need. The big drawback I see so far though is that it doesn't give realtime feedback. Unless I'm missing something here.
    Nevada
    593
    Blog Entries
    6
    There is a built in script/plugin that comes with lightwave (mine is in the Additional Plugins > generic Plugins > *REL:Make_Rel_Interactive) which should fix your problem and make relativity interactive.
    3D Generalist IGT
    Winston Salem NC
    202
    Quote Originally Posted by xchrisx View Post
    Wow. I'm really happy its actually something that I missed, and not something that just isn't there! Thanks a bunch Chris!
