Thread: Gamma Image Filter
    Registered User stevenpalomino's Avatar
    Jan 2010
    Kansas City
    607
    Gamma Image Filter
    Hey all,
    I couldn't help but notice that there's an image filter that says "gamma" in the layout processing tab.. would this be the same as the LW 10 linear workflow? Or is there a difference here?
    thanks!
    mostly yes, but not quite. Processing sRGB images to linear gamma is 'roughly' the same as a 0.4545 gamma. That has it's problems though, because 1) it can cause stepping, if you then apply the display gamma (the image filters throw data away, like it would in Photoshop) and also, because that conversion is only approximate. LW10 allows for custom lookup tables for more accurate image profile conversion.
    Linear Gamma has 'technically' been possible within LW for quite a long time, since it supported saving out floating point images, the new additions just help make that process less of a pain!
    luxowaver silviotoledo's Avatar
    Jun 2003
    Brazil
    1,831
    well..... I've seem Matt cool video that explains the theory about Gamma, but I'd like to see a tutorial step by step about how to use this tech. Any link?
    I mean:
    How do I de-gamma images and collors in lightwave?
    How do I reaply gamma at the end?
    Silvio Toledo
    Silvio Toledo
    Brazil
    Lightwave Pimp Skonk's Avatar
    Yorkshire UK
    1,450
    As in stands now I think it's just a case of manually adding the Full Precision Gamma filter to all your images in the image editor; and using it to de-gamma all your textures.
    Then adding the Gamma image filter from the image processing tab to re-gamma the final image.
    uh wha?
    Registered User speismonqui's Avatar
    Jan 2008
    Panama
    519
    Quote Originally Posted by silviotoledo View Post
    I mean:
    Silvio Toledo
    :agree:
    I want it too!
    I think Gerrardo goes into some of this in his tutorials on HDRI magazine
    http://www.artstorm.net/journal/2009...orkflow-cg-3d/ Artstorm also goes into it, in great detail...
    I also go into it in my 3D world video tutorial, but my way is not 100% correct!
    Sadly, with respects to LW 9.X there is no one or a simple solution to it, and
    •••••••••••••••••••• rsfd's Avatar
    Sep 2007
    Europe, de
    1,305
    I mean:
    Silvio Toledo
    Quote Originally Posted by speismonqui View Post
    :agree:
    I want it too!
    Easiest way: download Mike "Lightwolf" Wolf's db&w Tools.
    You'll find the "Simple Color Corrector" as Node, Image / Pixel Filter.
    You can linearize colors and images and you can use the Pixel Filter for previewing purposes on F9 renders (to have a "gamma-encoded" image in ImageViewer).
    If you render to a linear output for post-production, you should turn off the Pixel Filter for final output.
