Thread: Unify Polys - best practice? Any tips?
    May the sauce be with you starbase1's Avatar
    London, UK
    5,585
    I've got a model with quite a few duplicate polygons in it, and want to clean things up.
    Thing is if I just use 'unify polys' under detail, I get rather odd results, for example some polygons seem to end up with normals pointing the wrong way.
    Can anyone recommend a better way of using it than 'just click'?
    A big part of the issue is that its a very high polygon model, and if i can't see where it has been removing polygons, it's going to be horrible and impractical to try and check it over properly.
    Anyone know a way to highlight differences between 2 versions of a model, or otherwise identify where the overlaid polygons are?
    Faith is the opposite of Intelligence.
    Touched by his noodley appendage!
    My Lightwave Graphics & Downloads!!!
    If you mean--duplicates in the same mesh--can't you get some use from the stats panel for edges? Edges sharing >2polygons.
    London, UK
    5,585
    Quote Originally Posted by Rabbitpenny View Post
    Now that sounds like an interesting idea! While I can think of occasions where it would miss stuff, (for example if points are duplicated too, it's a different co-incident edge), that may well highlight areas of concern.
    And a quick test shows that some areas have this issue.
    Is there a way to go from selected edges, to selecting the polygons which use those edges?
    And anyone got a more comprehensive method?
    Thanks!
    Devastatin'
    Jun 2004
    London
    140
    look at edge stats and see if ">2 polygons is highlighted" that'll show you where errors are
    edit - whoops that'll teach me to read the whole thread
    if you go to the selection menu when you have these edges highlighted and click select polys it will convert the selection, also if you just have edges selected and you use 'hide unselected' it'll leave polys
    London, UK
    5,585
    Great, some stuff to try there, thanks!
    South Yorkshire, England
    2,500
    Old thread, but what a great bit of info. Came in handy today, so thanks.
