Results 1 to 9 of 9
Thread: VGA cable distance constraint
    I've always understood that the maximum length of a VGA cable is 6 feet. In order to have my Tricaster Pro more than 6 feet from the projector what are/is my options?
    Pete
    NYC
    3,332
    I don't know the exact limit but for a distance of 150', they sell DVI extender over CAT5 cable.
    FYI:I have not used one.
    Jose Burgos
    NewTek Certified Trainer
    www.burgosfx.com
    FaceBook
    Twitter @NYTriCaster
    19,325
    Quote Originally Posted by goswick View Post
    There are probably other options, but I have run monitors on 15 ft extensions.
    4,214
    We routinely run VGA 25, 50, 100' with good cables. By breaking out the VGA signal into RGBHV 5 coax runs can easily do 150-200' if needed.
    Gefen also makes a DVI to fiber and back to DVI cable that can run even further.
    6' is definitely not a limitation.
    The limitation is the quality of cable. If you can't find them locally at a computer shop or Fry's then shoot me an email with the length you need.
    Jef Kethley
    PIZAZZ
    www.pizazz.com
    Using:
    Panasonic UB300 4k cams
    Feb 2010
    Springfield MO
    15
    VGA over CAT5
    You should be able to run VGA up to 1,000’ over cat5 with an active VGA Balun and 150’ with passive Balun . We are runing VGA over CAT5 a 120’ at our church with no problem.
    http://www.mcmelectronics.com/produc...1GVA-/83-11350
    And
    http://www.mcmelectronics.com/produc...00042-/33-9603
    You can also run HDMI and DVI over CAT5 using Balun’s
    Registered User digiview's Avatar
    Apr 2010
    Encounter Bay SA
    364
    I have just started using a Aten KVM extender CE800 which works well good for 250m over cat5.
    Jan 2010
    Maryland
    76
    When I install ceiling projectors, I use 33' and 40' VGA high quality cables with no problems.
    Video Producer, So Calif.
    Apr 2010
    Irvine, CA
    200
    We routinely run our VGA's to screens without baluns 200'. BUT, we put a VGA distribution amp (splitter) behind the Tricaster to split the signal so that we can have a local VGA monitor at the tech table. The distribution amp bumps the signal. We got a 2x DA for like $50. We have run VGA around the perimeter of ballrooms without Cat5 baluns without a problem. We usually then loop-thru the projectors from one to another.
    www.TakeOneDigital.com
    Live webcasting from concept to broadcast * OC/LA/San Diego and Nationwide
    TC's: 300, 455, 460, Mini
    Cams: Sony PXW-X200, Pany HE-120 PTZ
    Cxns: HD-SDI over coax and fiber
    User
    Aug 2006
    Knoxville, Tn
    49
    We routinely do 200-300 feet over powered vga baluns. Eike makes a great one and even one that is vga in with a loop through and 4 cat5 out. Since we switched to this approach no more hum bars and picture quality is great. No more of that heavy rgbhv coax either. WE did a show in Vegas with 4 screens (15x20) for the Dooby Bros. and sent 720p down to the projectors. Stunning! Long live cat5!
