Thread: Depth min and max.
    Registered User Andyjaggy's Avatar
    Sep 2003
    Utah
    4,327
    Depth min and max.
    I ahve the need to control the max and min values of my depth buffer.
    I am trying to do with the min max buffer in the render global panel. However I can't seem to get anything other then a straight black or straight white matte. The problem might be the values. Are these using the scene units? Meters? Are they pixel brightness values? Are they the amount of times you've sworn at Lightwave during the day?
    Sep 2003
    Utah
    4,327
    I ended up creating the depth matte using fog instead as I couldn't ever get this to work.
    Dec 2006
    Philadelphia, PA
    5,738
    I usually use the depth buffer in the PSD export as a 16bit file leave the min/max settings as default and then just levels adjust the depth channel in PS afterward.
    Quote Originally Posted by Andyjaggy View Post
    lol
    Sep 2003
    Utah
    4,327
    Yeah it was a bad day. I decided to use Lightwave on a project at work, which I hadn't done in over a year, and it wasn't going so well.
    Dec 2006
    Philadelphia, PA
    5,738
    We've all been there!
