Results 1 to 15 of 23
Thread: strange shape
    Registered User bracki7's Avatar
    Mar 2009
    107
    strange shape
    Hi
    Till now I made a few bootle and jar, and sometimes on upper part of model is something strange. i don't know what. Example below:
    It exist independently of angle of camera. Below You can see my glass setting. And I used fast freshnel too. But with and without the result is the same.
    Any suggestions?
    But that something is obvious does not mean that it is true.
    Aug 2006
    S
    3,511
    The arc of the offending item obviously follows the geometry. Is the mesh clean as in no n-gons which shouldn't be there?
    - "w" then select >4 polys + to see if.
    Mar 2009
    107
    No. The geometry is clean. It was first what I cheked.
    Aug 2006
    S
    3,511
    Try "m" and "shift i", then check your stats "w" for 2 point polys. You won't see the problem in wireframe.
    Mar 2009
    107
    It was second thing what i checked
    "No points eliminated" and "No polygons eliminated".
    I chcecked geometry very carefully. Its clean for sure. For me something else.
    Mar 2009
    107
    Interesting thing, from fprime renderer, the jar looks good. Without any shape.
    Sep 2005
    Earth
    3,121
    Is the Jar and the cap one shape? Because if you want nice refractions you need a closed shape. that means if you applied 2 different surfaces to one model your refraction won't look right.
    To get nice realistic glass, use the "Dielectric" node.
    Aug 2006
    S
    3,511
    Ok, sorry missed that. Some part of the inner geometry is overlapping the exterior?
    Can't quite make it out in the wire but it looks a bit tight at some point. If you have the "inside" faces poking through the outside the various channels will just do what they do.
    Mar 2009
    107
    Quote Originally Posted by 3DGFXStudios View Post
    You mean are together? No. Glass of jar is one shape (closed). The same cap. Its one shape. On the glass poly is applied one surface.
    Mar 2009
    107
    Quote Originally Posted by meshpig View Post
    No. The surface of the glass has a thickness of 1 mm. maybe looks a tight, but is not. I still dont know why this happened. I resolve this problem in Photoshop now But it irritates me, why this is happening )
    Any other ideas?
    Aug 2006
    S
    3,511
    was going to say ps it... zip the object or pkg the scene and post it.
    Mar 2009
    107
    You're welcome. Indeed, so will be easier
    jar.rar
    Registered User Kuzey's Avatar
    Melbourne
    5,262
    I just checked the "exclude from vstack" button for the glass surface and it disappeared. Not sure what that would mean though...it's just the first thing I did
    Kuzey
    Aug 2006
    S
    3,511
    ... layer 3 had some stray points to merge. It also appears to be that which is striking through layer 1. Moving layer 3 aside removes the glitch, as in it's in the geometry
    Mar 2009
    107
    Wow! Ingenious!
    Really works! But how? What for is that button? And this mean that geometry is ok?
