Thread: Merging Separate Alpha sequences
    animate-a-holic
    Oct 2003
    Fairfield, California
    64
    I have always used 32 bit TGA files to output renderings so I can have an embedded alpha image within the file. I use After Effects, so it is usually very easy to interpret alphas that way.
    I have this job I am working on and the client wants to change the color of a single material, so I set up the scene to isolate that part via alpha channel and rendered it as a separate sequence. I would have re-rendered the entire scene, but it would take too long.
    I need to merge the new alpha with the original sequence so I can isolate the material, then change the hue to match the new mock-up that was approved by my client. Anyone know how to do this? Any help will be greatly appreciated. Thank you for your time.
    Greg
    Use the new alpha sequence as a track matte.
    place the one with the alpha on top of the original, select the original, go to layer/track matte/use alpha.
    animate-a-holic
    Oct 2003
    64
    AWESOME! Thanks Danner!
    G
