Results 1 to 10 of 10
Thread: how to merge 2 lwo's
    hello;
    I have:
    A.lwo with about 10 layers, all with uvmaps, textures;
    B.lwo with about 30 layers;
    I would like to merge the two lwo's into one lwo; the end result would have all 40 of the layers, where all layer names are preserved, as well as surfaces, textures, uvmaps;
    any thoughts;
    thanks,
    Shannon
    Michael Nicholson zapper1998's Avatar
    spokane washington usa
    4,663
    Blog Entries
    hmmmm
    i will get back 2 this in a minute
    will try something..
    automator of tasks xchrisx's Avatar
    Nevada
    593
    Blog Entries
    6
    i wrote this script a while ago for just that reason. just note that if you copy surfaces into an object with a surface that is named the same thing, the newly pasted object will take on that surface's properties
    http://chrisepeterson.com/lscripts/cp_meshcombine.zip
    This is probably stupid, but... could you try Scene2Modeler from Sven? http://svenart.de/lscripts.htm
    Load the objects in Layout and then run it.
    edit: ow well, chris, beat me at it =)
    Pixel and Poly Pusher JeffrySG's Avatar
    Dec 2006
    Philadelphia, PA
    5,738
    Quote Originally Posted by xchrisx View Post
    Very cool. I could have used that on a recent project. Chris, you should put a link to your site in your signature!
    Nevada
    593
    Blog Entries
    6
    done
    My Lscript Collection | LinkedIn
    3D Generalist IGT
    Chris, very cool;
    one suggestion: it would be nice if there existed an option to only copy selected layers to the target;
    also: you might want to mention that it also copies surfaces and uvmaps;
    unfortunately I spent 45minutes last night doing the task manually before I saw your script; it's always nice to see a labor intensive task get accomplished in mere milliseconds by a nice script;
    thanks,
    Shannon
    Nevada
    593
    Blog Entries
    6
    i should be able to add that feature just need to find some free time to do it
    3D Generalist IGT
    I have added an option to copy 'all', 'foreground', or 'background' layers. search on my name "shannon burnett" to locate all changes that I made.
    Code:
    @version 2.4
    @warnings
    @name "cp_MeshCombine"
        by chris peterson
        [email protected]
        http://www.chrisepeterson.com
        march 31 2006
        This script will combine multiple objects into
        a single object and preserve layer names.
        Known limitations:  Will not copy over pivots or hierarchy
    main
        layerdata    = lyrdata ( )   ; // Fill the array with all layers
    	emptyLayer   = lyrempty( )   ; // Find empty layer
    	curObj       = Mesh    ( 0 ) ; // Create a mesh from the current object so
    							       //      that modeler will recognize object.
    	curName      = curObj.name   ; // Assign the filename to a variable
        targetObjVal = 1             ; // Intialize variables for the requester
        whatToFill   = 1             ; // Intialize variables for the requester
        keepNames    = 1             ;
        swTarget     = 1             ;
        x            = 1             ; // Intialize the incrementer for the popup loop
    	if( !layerdata )
    	  {	// if no geometry throw error
            lyrsetfg( 1 )              ; // Set foreground to first layer
            ( "No geometry detected" ) ; // Tell user
            return 0                   ; // Tell it to be done
       else
            mesh = Mesh( ) || error( "No object files detected." ) ;
            while( mesh )
                objTarName    = mesh.name    ;
                setobject     ( objTarName ) ;
                nameList[ x ] = mesh.name    ;
                mesh          = mesh.next( ) ;
                x++                          ;
    		setobject( curName ) ; // when done go back to original file
    //////////////     REQUESTER BEGIN \\\\\\\\\\\\\\\
    reqbegin("cp_MeshCombine");
        reqsize(341,255);                                            //--<<<<<--  changed 05/23/10 by shannon burnett, to accomodate c6 ... see below
        c1 = ctlpopup("Target Object",targetObjVal,nameList);
        ctlposition(c1,32,71,180,21);
        c2 = ctlchoice("Paste to",whatToFill,@"Any Empty","Last Layer"@);
        ctlposition(c2,33,99,179,20);
        c3 = ctlcheckbox("Preserve Layer Names",keepNames);
        ctlposition(c3,37,164,175,22);                                //--<<<<<--  changed 05/23/10 by shannon burnett, to accomodate c6 ... see below
        c4 = ctlcheckbox("Switch to Target When Done",swTarget);
        ctlposition(c4,37,189,175,20);                                //--<<<<<--  changed 05/23/10 by shannon burnett, to accomodate c6 ... see below
        c5 = ctltext("","         Mesh Combine","       by Chris Peterson","[email protected]");
        ctlposition(c5,61,12,118,39);
    	//--vvvvv--  added 05/23/10 by shannon burnett
    	lvs_title                  = "which layers to copy?"                                                  ;
    	lvi_default_button         = 1        ;
    	lvas_options_for_copy_what = @ "all" , "foreground" , "background" @                                  ;
    	c6                         = ctlchoice( lvs_title , lvi_default_button , lvas_options_for_copy_what ) ;
        ctlposition                (c6,33,130,300,20)                                                         ;
        return if !reqpost();
        targetObjVal  = getvalue( c1 ) ;
        whatToFill    = getvalue( c2 ) ;
        keepNames     = getvalue( c3 ) ;
        swTarget      = getvalue( c4 ) ;
        lvi_copy_what_result = getvalue( c6 )                                     ;
    	lvs_copy_what        = lvas_options_for_copy_what[ lvi_copy_what_result ] ;
    	//info( lvs_copy_what )                                                   ;
    reqend();
    //////////////     REQUESTER END \\\\\\\\\\\\\\\
      targetObj = nameList[ targetObjVal ] ;      // Set target object to the name in the array
      if( curName == targetObj )
          error( "Cant send object to itself" ) ;
          return 0;
      else
    	  if      ( lvs_copy_what == "all" )
    	    { // do nothing, this is default case ... see  layerdata = lyrdata( )   ;
    		  // layerdata = layerdata ;
          else if ( lvs_copy_what == "foreground" )
    	    { // overwrite the default case, lyrdata(), with the subset lyrfg( ) ...
    		  layerdata    = lyrfg ( ) ;
          else if ( lvs_copy_what == "background" )
    	    { // overwrite the default case, lyrdata(), with the subset lyrbg( ) ...
    		  layerdata    = lyrbg ( ) ;
    	  // do the copying here
          setobject( targetObj ) ;
          secondObj  = Mesh(0)    ;
            								// that modeler will recognize the object
          targetName = secondObj.name;     // Assign the filename to a variable
          targetLyrData = lyrdata ( ) ;                // Layer data info of the target object
          lva_fg_layers = lyrfg   ( ) ;
    	  if ( targetLyrData == nil)
            { targetLyrData += 0;                // Incase the person sends it to an empty obj
          targetTotalVal = sizeof( targetLyrData )         ; // Get size of the layer data array
          targetLyrData.sortA( )                           ; // Make sure that the highest value is last
          targetLstIdx   = targetLyrData[ targetTotalVal ] ; // Get the last value in that array
          nextEmpty      = targetLstIdx + 1                ; // Increment to the next empty at end of file
          setobject      ( curName )                       ; // Set to first object
          layerdata.sortA( )                               ; // Sort the layer data in order
          for( i=1 ; i <= sizeof( layerdata ) ; i++ )
              lyrname  = curObj.layerName( layerdata[i] ) ; // Get the layer name of the selected layer
              lyrsetfg ( layerdata[ i ] )                   ; // Set layer to first layer with data
              selmode  ( GLOBAL )                         ; // Select everything in that layer
              copy     ( )       	                        ; // Copy contents to clipboard
              setobject( targetName )                     ; // Set the object to a different object
              if ( whatToFill == 1 )                  // If they selected ANY EMPTY
                { empL    = lyrempty() ;                  // Create empty layer
                  lyrsetfg( empL[1] )  ;                  // Set it to foreground
              else
                { lyrsetfg( nextEmpty );                // Find the next empty layer (at end of object)
              paste( ) ;					// Paste geometry in layer
              if( keepNames )
    		    {                       // If they opt'ed to keep names
                  if( lyrname )
                    { // If it has a layer name
                      setlayername(lyrname);	// Set it to the layer name
                  else
                    { setlayername("unnamed");	// If not just call it unnamed
              setobject(curName);		// Set to first object
              nextEmpty += 1;
          info("Layers copied to: ", targetName);
          if( swTarget )
              setobject( targetName ) ;		// Set to target
              lyrsetfg ( 1 )          ;
          else
              setobject( curName ) ;		// Set to source
              lyrsetfg ( 1 )       ;
    Nevada
    593
    Blog Entries
    6
    Cool additions Shannon. I noticed there was a bug in your code though because of how my script switches to the target object then switches back early on in the script, Lightwave actually deselects background layers. So all I did was define an array of foreground and background layers prior to that switching and everything runs fine. Thanks for that addition to the script
    Code:
    @version 2.4
    @warnings
        by chris peterson
        [email protected]
        march 31 2006
        updated may 23 2010
        thanks to shannon burnett for adding the background and foreground options
    main
      fgLyrs =  lyrfg ( ) ;  // Defined here so information isnt lost when switching to target object
    	bgLyrs = lyrbg ( ) ; // Defined here so information isnt lost when switching to target object
        keepNames    = 1             ;
        swTarget     = 1             ;
    	if( !layerdata )
       else
            while( mesh )
                x++                          ;
    reqend();
          return 0;
      else
    		  layerdata    = fgLyrs; //lyrfg ( ) ;
    		  layerdata    = bgLyrs; //lyrbg ( ) ;
              else
              if( keepNames )
                  if( lyrname )
                  else
              nextEmpty += 1;
          if( swTarget )
              lyrsetfg ( 1 )          ;
          else
              lyrsetfg ( 1 )       ;
    3D Generalist IGT
