Thread: Can't load scenes with morphs
    Mar 2010
    Chicago
    3
    As soon as I add a couple of morphs into a scene, I can't reload the file. Scrubs through just fine, renders fine, but if I save and try to reload, Layout just hangs up. I've spent an entire day trying to come up with workarounds...
    Hastings, New Zealand
    7,731
    what kind of morphs?
    Mar 2010
    Chicago
    3
    Endomorphs, each with one target map, using the Morph Mixer displacement to animate. I can add one endomorph to the scene and animate, it all works out fine. As soon as I add a second object with a morph target and apply the displacement, I can't reload the scene after saving. I thought maybe there was a naming convention conflict, but I've tried every approach to that with no luck.
    7,731
    Try removing morph mixer, adding in the new endomorph and then reapplying morph mixer.
