Thread: Orbital Scanning Camera
    SciEngArtist PabloMack's Avatar
    Dec 2007
    Houston, Texas
    348
    Question Orbital Scanning Camera
    I have an application where I need to create a render from an automated virtual camera that orbits a spherical object and produces a texture map by baking the 3D surface images into a flat 2D image that can then be used to surface a sphere. This is just like what landsat does to photograph the entire surface of the Earth and produce a 2D image. Is this possible with built-in features of LW? If not, is there a plug-in that can do it?
    Registered User bjornkn's Avatar
    Mar 2004
    Kristiansand, Norway
    549
    Surface baking camera should do the trick?
    The problem is to make a good spherical UV map without tris at the pole.
    Download sIBL and use one of the spheres there. They have great UV mapping, LatLong.
    Stuttgart, Germany
    13,585
    That basically sounds like an inverted panorama, the advanced camera should be able to handle that.
    Cheers,
    Mike
    Mar 2004
    549
    Quote Originally Posted by Lightwolf View Post
    Cheers,
    Mike
    How would you set that up?
    I use it with Cylindrical180 in both directions to make a spherical panorama, but that won't unwrap an existing sphere in the scene.
    There are a lot of settings there that I don't really understand though...
