Thread: Tech advice for moving LW to Windows 7 64bit please
    I've just upgraded to a new W7 64bit PC and I want to get my current LW licenses onto it.
    At the moment I'm running LW 8.5 and 9.3 off the same dongle on XP pro 32 bit.
    As I understand it (from a previous post) I can run both in 32 bit mode on the new system.
    Before I start installations etc I just needed some step by step advice as to what to do with license keys, sentinels drivers etc.
    My guess is that I can install the apps but Im not sure what to do after that.....
    Previous experience with LW installs has been a little convoluted for me and I'm trying to avoid too much down time with head scratching!!
    San Antonio, Texas, USA
    13,054
    Install the latest Sentinal drivers using this link:
    http://www2.safenet-inc.com/support/...testdriver.asp
    Then you will need to contact customer support to issue you with a 64-bit key for LightWave, just run LightWave 64 and jot down the dongle hardware ID, give them that, as well as your serial number.
    UI / UX Designer @ NewTek
